Have headers, but what to do with the alternator? - Team Camaro Tech
post #1 of 10 (permalink) Old Jun 11th, 01, 12:11 PM Thread Starter
Unhappy
I just bought a set of flowtech headers for my 67rs. My alternator is mounted to my driverside exaust manifold. I called summet to see if they had an adapter kit, but that was a no go. I wanted to see if any of you had run into the same situation.
thanx
james
Stock 67 327 RS
www.angelfire.com/ca7/goatjjcamarors/index.html
goatjj is offline
post #2 of 10 (permalink) Old Jun 11th, 01, 12:24 PM
did the same deal. mine is still mounted to the headers. and another bracket holds the front of the alt.
john
68rs-conv is offline
post #3 of 10 (permalink) Old Jun 11th, 01, 12:26 PM Thread Starter
Talking
How did ya mount it to the headers?
goatjj is offline
post #4 of 10 (permalink) Old Jun 11th, 01, 12:27 PM
DjD
DjD's Avatar
There should olny be one bolt that goes to the header. Most speed shops will sell a tube that can be cut to shim the bracket and you just use one of the old bolts.
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #5 of 10 (permalink) Old Jun 11th, 01, 12:35 PM Thread Starter
The top bracket is part of the manifold though. Im sorry the bottom is.(correction)
[This message has been edited by goatjj (edited 06-11-2001).]
goatjj is offline
post #6 of 10 (permalink) Old Jun 11th, 01, 12:41 PM
mine just mounted onto the headersand i put the bolt through the alt braket then the header.
post #7 of 10 (permalink) Old Jun 11th, 01, 02:49 PM
Many header manufacturers make alt. brackets, they seem to be fairly universal. You may have to trim the bracket a little to make it fit. Does your car have a/c?
68 convertible
ccpeat is offline
post #8 of 10 (permalink) Old Jun 11th, 01, 03:32 PM
I have a 67 with flowtech afterburner headers, I took one of the universal brackets ccpeat talked about (Mr. Gasket makes them) and welded it to the header flange. It normally bolts to the #1 header tube bolts. It works really well. You don't have to weld them but the bolts don't fit very good.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
squarles is offline
post #9 of 10 (permalink) Old Jun 11th, 01, 03:58 PM
I've seen chrome brackets for sale on ebay and at noahperformance.com to use with headers. Hope this helps.
Jim Byrd
1970 350 four bolt, .060, Speed pro hyper pistons, stock crank and rods, '77 vette GM manifold, edelbrock 600cfm, comp magnum 280H cam, '993' 75cc heads, comp springs, manley valves 1.96"-- In 1972 Nova, aka Camaro killer.
Jimmybyrd is offline
post #10 of 10 (permalink) Old Jun 11th, 01, 04:55 PM Thread Starter
Talking
Thanxs for the info guys.
you rock.
Stock 67 327 RS
goatjj is offline
