'69 ignition switch - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 5th, 01, 09:23 AM Thread Starter
I did a search on this and came up blank, how do you get the ignition switch out of a '69. The column is all apart and I must be missing a step. Thanks Wes
MY396 is offline
post #2 of 3 (permalink) Old Aug 5th, 01, 02:33 PM
David Pozzi
davidpozzi's Avatar
I have seen two types. One has a screw you take out then pull the lock.
The other has a thin spot in the casting near the inner end of the lock assy below the turn signal switch.
You pierce the thin pot metal in the proper spot and press a spring loaded tang on the lock assy to remove it. I don't remember if this lock also has the screw or not.
If you look at a replacement lock, you will see how it works.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old Aug 6th, 01, 12:39 PM Thread Starter
Thanks David, I am familier with the style that has the screw, which this doesn't. Drilling a small hole in the location of the tab was what I had to do, thanks again Wes.
MY396 is offline
