Linkage question - Team Camaro Tech
post #1 of 9 (permalink) Old May 9th, 01, 03:59 AM Thread Starter
I have a 69 camaro th350 trans and stock floor shift. What is the linkage that comes from the lever at the column in the engine compartment and down to a pivot on the frame and over to the tranny for? And since it is shifted by a cable could this be removed since the headers hit it?
Black 69 camaro
HOTROD69CAMARO is offline
post #2 of 9 (permalink) Old May 9th, 01, 04:09 AM
What it dose is locks your tranns in park when you trun your key off it also truns on your backup lights on when you go into revers. You can take it off but keep it a lot of people restoring cars are looking for them they are hard to find.
TIM
[This message has been edited by Tim Meredith (edited 05-09-2001).]
Tim Meredith is offline
post #3 of 9 (permalink) Old May 9th, 01, 05:04 AM Thread Starter
So am I going to need to fab a bracket or something to keep in the correct position? If the column doesnt lock thats ok, When I have the car out I'm never that far from it, but I would like the reverse lights to work. They do now. Is this possible?
Black 69 camaro
post #4 of 9 (permalink) Old May 9th, 01, 05:41 AM
Your lock out will not work. But on your reverse lights you could make a bracket for a bump switch to hit and turn them on.
TIM
post #5 of 9 (permalink) Old May 9th, 01, 05:55 AM Thread Starter
So once its unhooked, the positoin of wont matter or have a negative effect ont the column or the tranny?
Black 69 camaro
post #6 of 9 (permalink) Old May 9th, 01, 06:06 AM
No you will be ok some people tie them up to keep the backup lights from being on all the time.
TIM
post #7 of 9 (permalink) Old May 9th, 01, 08:03 AM Thread Starter
Thumbs up
Thanks for the help Tim
Black 69 camaro
post #8 of 9 (permalink) Old May 9th, 01, 10:27 AM
David Pozzi
davidpozzi's Avatar
Won't it prevent starting if in the wrong position?
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
post #9 of 9 (permalink) Old May 10th, 01, 01:42 AM
You are wright I forgot all about that. All you have to do is pull it up and tie it off to the brack line use a pull tie. Sorry about that.
TIM
