69 RS headlite vacuum? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 15th, 01, 05:56 PM Thread Starter
Rodney
I finally got my car running and after changing to the Holley Street Avenger carb, I don't have a place to hook up the vacuum for the lites. I thought about T'ing into the brake booster line. Would that work? It only uses a little vacuum when you turn them on, Right? I don't want to compromise the brakes but I just want the lites to work.
69 RS Camaro (383,350t,12-bolt w/3.73s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4,140k miles)
97 Bonneville SSE 40th Anniv. (3800 V-6, Power Everything, The little woman's car)
wildkatz is offline
post #2 of 4 (permalink) Old Jul 15th, 01, 06:27 PM
Paul
Hi Wild,
Hooking the hideaways into that line will be fine. The original connection was picked up from the port at the back of the intake manifold and not the carb anyway. I currently have the brake line T'd as well because my Performer RPM intake didn't allow me the room to screw in the original vacuum port tree. Good Luck, Paul
paul1969 is offline
post #3 of 4 (permalink) Old Jul 16th, 01, 02:58 AM
Rick
Holley makes a low profile fitting to fit under their carb.
Rick Dorion
69 RS Conv,355,M20,4.10's
RickD is offline
post #4 of 4 (permalink) Old Jul 16th, 01, 03:06 AM
Most of the parts places like Ricks, Classic Industries, D&R, etc. make the correct fitting to screw into the back of the manifold. They have them with up to 3 ports on them, one being the threaded fitting need for the brake booster, one for the TH350, and one for the RS setup.
When I had a holley on mine I never had any interference problems with the carb, using one of these.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
