T-56 manual linkage????? - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 10th, 01, 03:19 PM Thread Starter
Does anyone make a bellhousing/ throwout bearing for a T-56 that allows the use of the stock clutch linkage or do i have to use hydraulic?
jvolk81 is offline
post #2 of 12 (permalink) Old Jan 10th, 01, 04:31 PM
Sallee Chevrolet offers a T56 that uses manual clutch linkage. I don't know if they offer the parts separately or only with their tranny. You could give them a call at 541/938-5562 and find out. They also offer a mechanical speedo drive in theirs that does not require a conversion box. If you call them, I would be intersted myself if they offer it by itself. Hope this helps
Kevin
68 Camaro SS - In Resto
kdorsett is offline
post #3 of 12 (permalink) Old Jan 10th, 01, 04:46 PM Thread Starter
i checke their website and found that the mechanical linkage can only be used with the aftermarket borgwarner t-56 that they offer. http://www.sallee-chevrolet.com/
jvolk81 is offline
post #4 of 12 (permalink) Old Jan 10th, 01, 05:08 PM
Excuse my spelling, but Red over at McLeod has been producing some new scattersheilds for the OE and aftermarket trany's. You might want to give him a buzz. I'll have to get to the house and add his Phone# when I see my Rolladex.
chacane67 is offline
post #5 of 12 (permalink) Old Jan 11th, 01, 03:28 AM
jvolk81,
There is a company that makes a kit it includes bellhousing and hydraulic throwout bearing it's about $560 if memory serves correctly. I can provide more info about the company when I get home tonight. I found that I already posted the info try this link
https://www.camaros.net/forum/Forum9/HTML/001398.html
Sean James
67 camaro convertible
454 - 700r4
4:10 12 bolt
69 Firebird
[This message has been edited by mo67cam (edited 01-11-2001).]
mo67cam is offline
post #6 of 12 (permalink) Old Jan 11th, 01, 04:45 AM Thread Starter
My concern was in keeping the stock mechanical linkage. I dont really want to go to a hydraulic unless i have to.
jvolk81 is offline
post #7 of 12 (permalink) Old Jan 11th, 01, 03:08 PM
Edit: I replied thinking the car is a first gen, but if i recall it's a 2nd. sorry.
Tyler
[This message has been edited by Teetoe_Jones (edited 01-11-2001).]
Teetoe_Jones is offline
post #8 of 12 (permalink) Old Jan 11th, 01, 05:20 PM Thread Starter
HUH? this is for a first gen. I wouldnt be caught dead in one of those seventies things J/K
jvolk81 is offline
post #9 of 12 (permalink) Old Jan 11th, 01, 05:40 PM
Oh in THAT case- email me and i'll set you up with the easy way to run the hydraulic clutch.
Tyler
1968 RS/SS Camaro w/ 94 vette LT-1 and T56 six speed, Cal-Tracs, Baer 12" crossdrilled brakes 17" rims, ect....
<A HREF="http://home.earthlink.net/~speedracer68/tyler.htm" TARGET=_blank>
My 68 with LT1 and T56</A>
post #10 of 12 (permalink) Old Jan 30th, 01, 11:11 AM
MARK
Send a message via AIM to PROZ11
<BLOCKQUOTE>quote:</font><HR>Originally posted by jvolk81:
Does anyone make a bellhousing/ throwout bearing for a T-56 that allows the use of the stock clutch linkage or do i have to use hydraulic?<HR></BLOCKQUOTE>
PROZ11 is offline
post #11 of 12 (permalink) Old Jan 30th, 01, 11:15 AM
MARK
Does anyone make a bellhousing/ throwout bearing for a T-56 that allows the use of the stock clutch linkage or do i have to use hydraulic?<HR></BLOCKQUOTE>I don't know if you got your answer yet, I just went thru this swap and in the months of research I did I could not find any way of using the stock or any other manual linkage. You must go with the hydraulic set up. I did.
PROZ11 is offline
post #12 of 12 (permalink) Old Jan 30th, 01, 04:43 PM
As chacane67 said Mcleod is supposed to have a scattershield that will bolt a production T-56 to an older style block that, I believe will retain the mechanical linkage. WEIRs hot rod products has a heat treated aluminum b-housing that will work like Mcleod b-housing only youll have to go with the juice clutch,thats the one for$560 The aftermarket T-56 at SALLES can be drilled to fit older b-housings,has a mechanical speedo and a different length input shaft which allows it to be used on the older b-housings ,which gets you mechanical linkage.Of course it costs considerably more than used production model!
68 candy brandywine 383dfi/T-56 87 monte carlo ss aerocoupe
EDAVIS68DFI is offline
