327 TIMING GEAR TORQUE SPECS - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 12th, 01, 02:22 PM Thread Starter
Can anyont tell me how far to torque the timing gear bolts on a '68 327.
Also the torque specs for the timing cover.
Any help is appreciated.
Thanks,
AL
algenard is offline
post #2 of 4 (permalink) Old Apr 12th, 01, 04:38 PM
Cool
timing cover 80 in-lbs
cam sprocket 20 ft-lbs
69 Camaro SS 350 4 speed
55 Belair Sedan Pro Street 355 auto 9''
gene stills is offline
post #3 of 4 (permalink) Old Apr 12th, 01, 05:37 PM Thread Starter
Thumbs up
Thanks Gene,
One other question if I may.
We are installing an Edelbrock double row gears and chain. It had been a long time since I did one of these and back then I had a little more control since the engine was out of the vehicle. Best I remember I was able to turn things from the flywheel on that one.
This time the engine is still in the car and I had to turn the cam with a rachet on one of the timing gear bolts to get the distributor in the right position. Even though the plugs were out, the bolt locked down pretty tight, (I'm sure much, much more than 20 ft. pounds).
I figure to replace all the bolts with new grade 8 and heavy duty Locktite. I wondered if it would hurt to torque any heavier, even though I don't think I hurt the threads. I just don't know how tough the cam threads are.
Thanks again,
AL
algenard is offline
post #4 of 4 (permalink) Old Apr 12th, 01, 06:52 PM
Lightbulb
Al. Im sure you could go 25 ft-lbs on the five sixteenths grade 8 bolts.loctite would be alright too,or you could go with a cam locking plate,You can get them thru jegs,summit,etc for around 5 bucks with bolts.
