Timing tips for mild cam? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 17th, 01, 06:10 AM Thread Starter
I am a 69 SS 350/300 Camaro owner. I recently installed an Engle EP 20 cam. I have also installed a massaged distributor with HEI. I set my timing at 31 deg @ 3000 RPM, adjusting the Holly 650 lean then back out 1/4 turn. It does'nt perform as I had hoped. Also, should mention it has stock intake & no headers. Getting it to sound good and run right at the same time is a problem. Any good timing tips? I've never had other than stock cars before. Carl
lracss96 is offline
post #2 of 3 (permalink) Old Jul 17th, 01, 04:43 PM
you need to adjust your carb using a vacuum gauge or at least a tach.....u failed to mention what u did to the dist....have u checked the entire timing curve...initial should be good around 10 deg or so....could be all the advance is coming in too soon...
jblake is offline
post #3 of 3 (permalink) Old Jul 17th, 01, 04:44 PM
P.s. about 36 degrees total timing without the vaccuum advance will probably work better
jblake is offline
