Whats crank balance..??? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 3rd, 01, 10:07 PM Thread Starter
Exclamation
what is the dif. between int/ext/ and what should i get if i want to stroker a 350 and used as many parts from it as possible..should i use a 400 crank or a 383 crank
WILDER-Z28 is offline
post #2 of 2 (permalink) Old Aug 4th, 01, 01:23 AM
I talked to alot of experienced people before I started with my 383 stroker.Everyone sais that internally balanced is better.It can cost more for the balancing when you go internal,but you can also use your 350 balancer and flywheel/flexplate wich saves you money.All of the internally balanced 383 crankshafts Ive seen require the use of 6 inch rods,wich is ok because longer rods are better anyway.Go internal,its the way to go.
nitrous383 is offline
