JL- 8 rear end - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 3rd, 00, 05:51 PM Thread Starter
Were the JL8 axles tapered on the end of the axle housings where it connected to the backing plate, or was it the other way around? Thanks for the help
CORNHOLIO is offline
post #2 of 12 (permalink) Old Jul 4th, 00, 06:57 AM
The JL-8 had the tapered axle tubes. Note there was an over the counter "service package" disc rear end that did not have the tapered axle tubes. Either one would be excellent on a road racer.
70 RS/Z-28 is offline
post #3 of 12 (permalink) Old Jul 4th, 00, 02:02 PM Thread Starter
ummmmmm I took mine out to replace bushings etc. and it has tappered ends, but has drum brakes. what do you think, did someone put drums on this one when it came to needing replacement?
post #4 of 12 (permalink) Old Jul 4th, 00, 07:56 PM
Charley
clill's Avatar
Cool
Cornholio have you been sniffing TP ? Sounds like you have a drum rear. And where in the rear is a Bushing ?
clill is offline
post #5 of 12 (permalink) Old Jul 5th, 00, 02:54 AM
Clill, whats TP, I think I want some. Wait, maybe I don't.
Cornholio, I know the taper your talking about, its not the same as the JL-8. There are pictures around somewhere that I seen. If you really suspect it may be one then let us know the numbers off the pass side front of the axle tube. Is your car a Z? If your replacing bushings then maybe its a Chevelle JL-8 unit? Sorry had to throw that in, no offense.
68SS396 is offline
post #6 of 12 (permalink) Old Jul 5th, 00, 06:46 AM
To me the taper looks the same on a JL8,and a drum rear.Ive looked at them side by side,the only difference I can see thats not bolt on, is the brackets for the emergency brake cables.Which are welded on both sides.The codes on the axle tube should tell you what it started life out as.I agree with clill,sounds like a regular drum rear.Stay off the TP.
Boomhauer is offline
post #7 of 12 (permalink) Old Jul 5th, 00, 05:02 PM Thread Starter
Whats TP? The bushings I'm talking about are the ones in the spring eyes and the ones between the rear end and the springs. Yea its a Z I just bought it.
post #8 of 12 (permalink) Old Jul 5th, 00, 05:42 PM
Charley
clill's Avatar
For those of you that are Cornholio challenged. Cornholio is a Beavis and Butthead character that wanders around saying " I need TP for my Bunghole "= Toilet Paper. Are you threatening me ??????????
clill is offline
post #9 of 12 (permalink) Old Jul 6th, 00, 02:31 AM
Jeff
And he drinks "crappacino"! I figured someone would be explaining that one to you clill, not the other way around. By the way, the car is sitting in the garage and I haven't touched it in a couple of months. Too many other things going on to even think about it.
Jeff H is offline
post #10 of 12 (permalink) Old Jul 6th, 00, 05:23 PM
clill, you are a true renaissance man. Not many guys know their Beavis and Butthead as well as a '69 COPO.
jbradway is offline
post #11 of 12 (permalink) Old Jul 6th, 00, 05:41 PM
DjD
DjD's Avatar
I was afraid to ask? With the topic being about rear ends and all!!
...Dennis
Topless'69
Camaros Limited Nor-Cal
[email protected]
[This message has been edited by DjD (edited 07-06-2000).]
DjD is offline
post #12 of 12 (permalink) Old Jul 7th, 00, 04:26 AM
Charley
clill's Avatar
Somewhere I still have a battery operated Tee Shirt that when you press certain spots Beavis or Butthead say things. Someday I'll grow up. Nahhh.
clill is offline
