Where can I get some BB FRAME MOUNTS, ANYONE PLEASE!! - Team Camaro Tech
post #1 of 16 (permalink) Old Apr 24th, 00, 08:06 AM Thread Starter
Chris
I need some big block frame mounts for my 69 camaro thankyou.........!!
Procharged69 is offline
post #2 of 16 (permalink) Old Apr 24th, 00, 08:59 AM
I think the 69's are still available. Its the 68's I'm looking for thats tough
68SS396 is offline
post #3 of 16 (permalink) Old Apr 24th, 00, 09:50 AM Thread Starter
Chris
Nope, the 69's are hard to find too. Discontinued from GM.
I really could use some 69 BB frame mounts.
post #4 of 16 (permalink) Old Apr 24th, 00, 10:46 AM
I think you can use the 67/68 series frame mounts on the 69's but you must use the 67/68 engine mounts. I just picked up some 67/68 BB frame mounts about 3 - 4 months ago. One was readily available, but the other was hard to find.
67 Camaro LS6 454/TH400/12bolt 3.73
cardude is offline
post #5 of 16 (permalink) Old Apr 24th, 00, 11:58 AM
There is a set of BB mounts on this site for sale under 69 camaro parts,
DON MAHAN
NVMYSS is offline
post #6 of 16 (permalink) Old Apr 24th, 00, 03:02 PM
Thumbs up
There is a pair just put on E-bay auction item #317045260
DON MAHAN
NVMYSS is offline
post #7 of 16 (permalink) Old Apr 24th, 00, 08:43 PM
I'm almost certain that the frame mounts for the big block are the same as the 302 and 350. The 307/327 was considered a low performance V8 that used smaller engine mounts and taller frame mounts. I can get the part numbers off of mine if you havn't gotten anywhere yet...
Firestone is offline
post #8 of 16 (permalink) Old Apr 25th, 00, 02:19 AM
Firestone, Check out the numbers that you have. I have a pair of 69 BB mounts that I bought a few years ago and ended up not using them. Don't have the numbers handy but I remember them being different from all the SB. Here's one, why and what are the differences between the 68 BB and 69 BB mounts? The only differences between the years is going from the short water pump to the long water pump. The frame mounts don't move the motor for or aft so whats the difference besides the part number?
68SS396 is offline
post #9 of 16 (permalink) Old Apr 25th, 00, 04:48 AM
There is a width difference in the frame mounts between the 67/68 cars and the 69 cars.
What it boils down to is you can't mix the frame mounts & motor mounts between the two.
One combination won't even fit and the other will be loose.
I'll look through my archives and repost when I find the exact info.
cardude is offline
post #10 of 16 (permalink) Old Apr 25th, 00, 09:40 AM
'69 BB frame mounts are different than all the others as the driver side is taller than the passenger one. This is because the BB isn't centered in the engine bay to provide steering clearance. I just bought some from a Chevy dealer two months ago.
Kevin is offline
post #11 of 16 (permalink) Old Apr 25th, 00, 01:28 PM
Kevin is correct ,on the big block mounts one is taller than other, small block mounts will not work.
DON MAHAN
NVMYSS is offline
post #12 of 16 (permalink) Old Apr 26th, 00, 02:00 AM
Actually the SB mounts can work for installing a BB. Seen it done many times, just not correct. I Realize the height difference between the BB and SB mounts but not the difference between the 68 BB and 69 BB mounts.
68SS396 is offline
post #13 of 16 (permalink) Old Apr 26th, 00, 03:03 AM
Thumbs up
Hey,
I got this info from one of clill's posts. the current part #'s that are still available from Chevy are #03980941 and #03980942. I called a dealer yesterday and they told me they cost about $25 each, I have yet to buy mine. Don't know the exact year but the previous topic was on a 68.(Big Block Frame Mounts, Steve R was the author). Good Luck
mo67cam is offline
post #14 of 16 (permalink) Old Apr 26th, 00, 04:47 AM
SB mounts will work, have seen it done many times, just not correct. I realize the BB mounts have different heights between the right and left sides. Just didn't understand the difference between the 67-8 BB mounts and the 69 BB mounts. Sounds like cardude hit it. Different width's between the years.
68SS396 is offline
post #15 of 16 (permalink) Old Apr 26th, 00, 10:44 AM
Charley
clill's Avatar
I believe that one of the mounts is now no longer available :-(
clill is offline
