need help with coolant lines - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 24th, 00, 04:34 PM Thread Starter
Lightbulb
i am trying to find the easiest way to remove coolant lines on a 85 camaros.
fleaman is offline
post #2 of 2 (permalink) Old Apr 24th, 00, 07:37 PM
if you dont mind to damage the hose you cut a slit into the hose till it geos of the conection and the hose should easily come off
if you dont want to damage the hose use a screwdriver between the hose and pipe and work around the pipe and the hose should come off easy
Athorn4941 is offline
