floor - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 7th, 01, 05:46 AM Thread Starter
is it good or not and why?
the floor of a 1980 camaro z 28 been restor and been cover of fiberglass inside the car the trunk and all under the cars.
is it possible that make the floor rust because of no breaving..
well any info will be very appreciate
thanks a lot
noel80z28 is offline
post #2 of 6 (permalink) Old Feb 7th, 01, 05:54 AM
it may be possible that the floor was rotted out, so instead of replacing the floor they covered it with fiberglass, I dont think that would cause it to rot because it would be sealed, unless they put the fiberglass on the car when it was all wet, never know ...
god luck stripping it off, better wear a respirator, those fiberglass dust dont go to well with human lungs..
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #3 of 6 (permalink) Old Feb 7th, 01, 08:27 AM
Robert
I put a thin layer of fiberglass over my floor pans because of some small holes. To me it didn't justify replacing the entire pan especially on a driver. However, I covered with POR-15 before the fiberglass. I have a 77 Dodge truck that this was done to back in the mid 80's because of rust created by the air-cond. leaking inside the cab instead of out. The Dodge floor is no worse off over 15 years later. Of course if your working on a future show car and have it apart, now would be the time to fix it.
Robert
'69 getting better every day... (every pay day)
[This message has been edited by rojo (edited 02-07-2001).]
rojo is offline
post #4 of 6 (permalink) Old Feb 7th, 01, 08:46 AM
here in iowa, they put this stuff they call SALT (calcium choride) on the roads during the winter to melt the ice. if you have the same problem in canada and if they covered the floor with fiberglass with salt still on the metal,it would be very possible...if moisture can get in anywhere past the seams
scott
[This message has been edited by scott lauters (edited 02-07-2001).]
scott lauters is offline
post #5 of 6 (permalink) Old Feb 7th, 01, 02:09 PM Thread Starter
Cool
ok the car have not been drive in winter for a long time dont know how much. The jog been done for protecting the under of the car and the inside is it good to proctect the car that way?
and something else the fiberglass under the car could it take in fire were the pipe and muffler are?
And this is not well rigth now for a show car i whant to enjoy it.
thanks for all...
post #6 of 6 (permalink) Old Feb 8th, 01, 07:58 AM Thread Starter
Talking
hi!
