What is the difference between a 12 bolt and 10 bolt rear? - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 7th, 01, 11:58 AM Thread Starter
Yeah I know it sounds stupid, but I don't know the difference.
Thank you in advance,
Sean
69musclecar is offline
post #2 of 10 (permalink) Old Feb 7th, 01, 12:17 PM
2 bolts
seriosly the 12 bolt is a stronger unit,and was used for big blocks and z28's.
CORNHOLIO is offline
post #3 of 10 (permalink) Old Feb 7th, 01, 12:33 PM Thread Starter
What I ment to say was how do you tell the difference?
Thank you in advance.
Sean
post #4 of 10 (permalink) Old Feb 7th, 01, 12:40 PM
Only way to tell for sure is to pull the cover and count the bolts in the ring gear. However, most 10 bolt rears have 10 bolts in the cover, and the same for 12 bolts. So you can just glance under the car and count the bolts on the cover and that's probably correct. A 12 bolt will have 2 bolts on the bottom, parallel with the ground, if that makes sense, and a 10 bolt has only one bolt at the bottom of the cover, so it's real easy to tell the difference once you know what to look for.
No 'E' in Camaro is offline
post #5 of 10 (permalink) Old Feb 7th, 01, 01:11 PM
Thats what I meant as well, just by the name. 10 bolts have 10. 12 bolts have 12.
post #6 of 10 (permalink) Old Feb 7th, 01, 03:03 PM
Just two bolts.
1st & 2nd GENGuy is offline
post #7 of 10 (permalink) Old Feb 7th, 01, 03:39 PM Thread Starter
Thank You guys.
post #8 of 10 (permalink) Old Feb 7th, 01, 03:41 PM
If you look under your car from the back and there are two bolts on the bottom next to each other ( the same distance from the ground) then it's a twelve bolt. I don't know if you know what I mean but a ten bolt will be such that only one bolt will be at the lowest point on the rear.
Dan
danL is offline
post #9 of 10 (permalink) Old Feb 7th, 01, 06:45 PM
yea, 10 bolts are like a circulaur pattern. While 12 bolts are kinda like staggered.
post #10 of 10 (permalink) Old Feb 7th, 01, 06:46 PM
oh yea, 12 bolts have more splines in the axles themselves and are thicker too.
