Stock Tachometer Flutter - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 6th, 01, 12:19 PM Thread Starter
My 67 has a stock 5500 redline tachometer and the needle flutters (bounces is probably a better term) very badly. Seems to have no distinct pattern, its not unbearable but annoying especially when you really need to use the tach. Does it need lubrication, calibration, or all of the above. I'm interested to see what others have done to combat this problem. Thanks in advance.
Barry H is offline
post #2 of 3 (permalink) Old Aug 7th, 01, 03:30 PM
Tim
I'm not familar with an OEM tachometer but expect it to be electrical. My aftermarket tach bounced and I traced it to a simple shorting problem where the wire passes thru the firewall. Somehow the grommet was missing (I never installed it-oops) and wore thru the insulation.
Hope that helps.
1969 Nova SS 350
406/M20/3.55
13.68 at 105
L48M20 is offline
post #3 of 3 (permalink) Old Aug 7th, 01, 05:19 PM
Worn points can also cause this problem!
Justin Traunero
[email protected]
-1967 Camaro SS350 clone
http://156.143.134.136/default.htm
jrt67ss350 is offline
