67 RS headlight motor wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 12th, 99, 08:11 AM Thread Starter
Jeff
My headlight motors are not working correctly. When you turn on the lights, the doors barely move and then stop right away as they release the button on the relay. Where can I find the correct wiring diagrams? Thanks, Jeff.
Jeff H is offline
post #2 of 4 (permalink) Old Oct 19th, 99, 12:39 AM
JEFF
Did you get your head light problem fixed?, or do you still need help?.
GEAR HEAD is offline
post #3 of 4 (permalink) Old Oct 19th, 99, 07:46 AM Thread Starter
Jeff
I ended up pulling wires on and off the connectors and then they started working properly. It may have been a grounding problem. Thanks anyway.
Jeff H is offline
post #4 of 4 (permalink) Old Oct 27th, 99, 03:16 PM
JEFF,
GLAD TO HEAR YOU GOT YOU'RE MOTORS WORKING. CLASSIC INDUSTRIES SELLS A WIRING DIAGRAM FOR THE 67 RS HEADLIGHTS. IT SAVED ME, YOU MIGHT WANT TO GET ONE JUST IN CASE YOU EVER NEED IT. JUST TAKE A LOOK AT THE TANGLE OF WIRES AND RELAYS UNDER THE LEFT FRONT FENDER AND YOU WILL UNDERSTAND WHY. THESE CONTROL THE OPENING AND CLOSING OF THE DOORS ALONG WITH THE LIMIT SWITCHES. THE BOOKLET ALSO HAS CENTER CONSOLE GAUGE WIRING DIAGRAMS IF YOU'RE CAR IS EQUIPPED
67FREAK is offline
