Quadrajet Assembly - Team Camaro Tech
post #1 of 5 (permalink) Old May 26th, 01, 03:03 PM Thread Starter
Putting new lighter power valve spring in my Q-jet tonight -
I HATE doing the Choke Lever (between the choke on the primaries & the choke linkage)
Anyone have the "perfect" tip on how to do this easier -
do you do it with the carb top partially on -
or
after the top is screwed on (I call this the fishing method)
There has to be a "right" way - I just don't know it....
Thanks for the input
Dobek is offline
post #2 of 5 (permalink) Old May 26th, 01, 03:15 PM
ZZ_430's Avatar
You know what works good is a "magic fingers". It's just a small piece of brass tubing with piano wire inside with a hook at the end. Spring loaded with grip to pull or retract. Any tool truck (Snap-on, MAC etc)will have one. works great! (with top on) http://hometown.aol.com/zz430droptop67rs/
[This message has been edited by ZZ430DropTop67RS (edited 05-26-2001).]
ZZ_430 is offline
post #3 of 5 (permalink) Old May 26th, 01, 05:33 PM
Dale
I do it with the carb completely assembled.I guess you would call it the fishing method.I have shined a flashlight into the hole,then I can see .I guess it becomes easy with some practice.Once you hit the hole,a little jiggling,and it's done.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #4 of 5 (permalink) Old May 26th, 01, 06:20 PM
With a little practice the fishing method works fine. You need to shine a light in the hole so you can see what is going on and most important don't get flustered it will go in
oger is offline
post #5 of 5 (permalink) Old May 27th, 01, 04:54 AM
Bill
Steve,
I have found the best way to do this is with the carb on its side. I clamp it in the vise by one corner of the baseplate. That way you can get a medium straight blade screwdriver in the hole, line up the lower choke arm and put the choke on quite easily. I do this almost last while assembling the carb.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1973 Z-28 ..one family car...Brother bought it new in 73
BillK is offline
