Big Block Heater - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 9th, 01, 10:15 PM Thread Starter
Joe
Well, here's another dumb question for the experts. After searching for the info I got confused (imagine!).
What is the difference between a BB heater core and SB core? My 69 was converted to a 396 by a previous owner. It seems to have been done (mostly) right.
The heater hoses enter and exit by the passenger side fender. I thought it was the original SB core but, as usual, I think I'm wrong.
Can you guys help?
Thanks again
Joe (The more I learn, the more I need to learn)
69 SS396 Clone, B&M TH400, 3.55 12 Bolt Posi, Blue w/White Z28 Stripes, Chrome Rally Wheels
[email protected]
Joe G is offline
post #2 of 5 (permalink) Old Feb 10th, 01, 12:33 AM
I'm not an expert, but the big difference is the box on the firewall. for BB it is different to clear the right bank valve cover. if your valve cover has good clearence then i'd say your ok. Zappo
zappo is offline
post #3 of 5 (permalink) Old Feb 10th, 01, 02:58 AM
The big block one is different. The tubes are longer and straighter than a small block so they can pass through the heater duct. The small block tubes have a 45 degree bend in them to clear the back of the engine that the big blocks don't have. The heater tubes are also swapped where they go into the core so that the 3/4" tube stays on the top. If you turn a smallblock core around to use it in a big block the 3/4" tube will end up on the bottom.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 5 (permalink) Old Feb 10th, 01, 08:22 AM
kz1000ltd is offline
post #5 of 5 (permalink) Old Feb 10th, 01, 08:51 PM Thread Starter
Joe
Mine has a 5/8" hose on the bottom. It exits the firewall almost on the inner fender on the passenger side. The top hose is SS Braided, but it is a bit larger than the bottom one so it could be 3/4". Both hoses exit close to the passenger side fenderwell. Does the other model exit close to the engine heads? If so, I can see why there would be clearance problems. Mine are so far away from the engine that it doesn't enter the picture. The hose are attached to the fenderwell.
Maybe it is an aftermarket heater? The heater cover in on the firewall looks stock.
Maybe I should just be happy it runs!
Thanks, Joe
[email protected]
[This message has been edited by Joe G (edited 02-10-2001).]
Joe G is offline
