Ignition lock cylinder - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 8th, 01, 11:19 AM Thread Starter
Hi, I want to put in a new ingnition lock cylinder. Can anyone tell me how to get the old one out.
Thanx,
Jason
67427BB is offline
post #2 of 9 (permalink) Old Aug 8th, 01, 12:52 PM
what year?
67/68 dash key unscrew the bezle knob and remove the lock assy, there is a clip /pin inside you remove and the key tumbler falls out. replace in reverse order,
69 column key - put a pin in the hole and turn to ACC position, the tumbler falls out.
Chris's 67 RS 327, Comp280,Flowmasters,shoddy interior, pepboys carpet and rusty floors and trunk can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #3 of 9 (permalink) Old Aug 8th, 01, 01:23 PM Thread Starter
It's a 67. I don't see no threads on the assembly anywhere. Thanx
67427BB is offline
post #4 of 9 (permalink) Old Aug 8th, 01, 02:04 PM
Jason, I think that you have to turn the ign cyl to the accessory position and insert a straightened paper clip into the small hole that is next to the key and continue to turn until it stops and then pull it out, it should come out quite easily.
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
If you have no fear, you're not going as fast as you could.
[This message has been edited by chev64 (edited 08-08-2001).]
chev64 is offline
post #5 of 9 (permalink) Old Aug 8th, 01, 02:07 PM
JohnZ's Avatar
To remove the cylinder, put the key in and turn it to "Accessory", then use a bent-open paper clip in the little hole next to the key; push it in (you'll feel a spring) all the way, and you can then turn the key counter-clockwise some more and it'll pop right out. Then you can unscrew the bezel and remove the ignition switch.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #6 of 9 (permalink) Old Aug 8th, 01, 02:51 PM Thread Starter
Thanks guys. That worked pretty slick.
Jason
67427BB is offline
post #7 of 9 (permalink) Old Aug 8th, 01, 02:53 PM Thread Starter
Now, how do you get the new one in?
67427BB is offline
post #8 of 9 (permalink) Old Aug 9th, 01, 02:30 PM
If you look at the back of the one that you pulled out, You should see how that trick with the paper clip works and you need to turn the new one to accessory,push in with paper clip again while continuing to turn until it stops and insert it and turn it to all the positions and all should be fine.
Leo Paugh
MCC #017
chev64 is offline
post #9 of 9 (permalink) Old Aug 9th, 01, 02:48 PM Thread Starter
Thanx, worked like a charm. Looks nice with new lock cylinder.
Jason
67427BB is offline
