DZ302 distributors - Team Camaro Tech
post #1 of 7 (permalink) Old May 27th, 01, 04:00 PM Thread Starter
Gary
69Z28's Avatar
I heard or read somewhere that the shaft in the 1111480 distributor was different than other GM distributors. Is this true? I found a distributor but it is thoroughly trashed from corrosion and pitting. Must of sat in water for many years. Anybody know where you can get a replacement? How about the correct vacuum canister. I have a Crane adjustable I plan on using if there aren't any around. Any suggestions on what I can do to get a standard none 302 GM distributor to work?Looking to keep it all stock looking as well.
Gary
69Z28 is offline
post #2 of 7 (permalink) Old May 28th, 01, 02:09 PM
If I remember correctly the only difference was the lobes had a more gentle point opening ramps to reduce point float at high RPM.
oger is offline
post #3 of 7 (permalink) Old May 28th, 01, 04:15 PM
Also the 302 points have their on P/N. The points on the 302 cars have stiffer springs on the points to help prevent points from floating at high rpm.
69 Camaro SS 350 4 speed
55 Belair Sedan Pro Street 355 auto 9''
gene stills is offline
post #4 of 7 (permalink) Old May 28th, 01, 04:25 PM
DjD
DjD's Avatar
I was of the understanding the curve was different as well. I don't know that for a fact though. Maybe John Z will drop in!!
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #5 of 7 (permalink) Old May 30th, 01, 10:31 AM
JohnZ's Avatar
The 1111480 distributor used (only) in the DZ application has a unique long-slot advance cam and much closer tolerances on the (hardened) shaft and housing bushings. If the one you have is badly corroded, try Jerry MacNeish at(410)781-0418 for a quote on a rebuild, or T.I. Specialties in Florida ( www.tispecialty.com ). I haven't seen a decent genuine 480 distributor go for less than $450 recently (even 480's are being re-stamped now that they are so valuable). If numbers are important to you, I'd try and save it. Jerry's doing my 480 right now.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #6 of 7 (permalink) Old Jun 5th, 01, 01:01 PM
Kurt S
Kurt S's Avatar
The advance cam is part of the shaft and is stamped 532 (32 degrees advance). The 532 cam is also used in couple other 69 distributors.
Kurt S.
CRG www.camaros.org
Kurt S is offline
post #7 of 7 (permalink) Old Jun 6th, 01, 03:56 PM
frank
I was just into mine the other day. Its the 480 distributer. On the plate where the points mount its stamped with part#2769047.Does anyone know if this is the right plate for the distributer?
frankk is offline
