10 or 12 bolt Rear End - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 10th, 01, 01:45 PM Thread Starter
I understand the difference between a 10 & 12 bolt rear end. Is there any performance ordifference between the two? If so which is better? I have a 67 SS Convert. Thanks
Gambler is offline
post #2 of 6 (permalink) Old Feb 10th, 01, 02:07 PM
I could be wrong, but the way I understand it, the 12 bolt is a stronger rear-end.
69musclecar is offline
post #3 of 6 (permalink) Old Feb 10th, 01, 03:10 PM
Procurement_man's Avatar
If your car is a true SS you have a 12 bolt. if not it's a 10. The 12 bolt is a heavy duty rearend and will handle the extra power of the 350 or one of the big blocks. Rebuild cost is high for one and outright is about $1000
Procurement_man is offline
post #4 of 6 (permalink) Old Feb 10th, 01, 09:11 PM
Thumbs up
<BLOCKQUOTE>quote:</font><HR>Originally posted by Gambler:
I understand the difference between a 10 & 12 bolt rear end. Is there any performance ordifference between the two? If so which is better? I have a 67 SS Convert. Thanks<HR></BLOCKQUOTE>
You might want to toss in other environment variables the Camaro is subjected to when calculating things like performance with 10 or 12 bolt rear ends.
I would have to say is that there is not much difference unless your going a 150+ MPH and the differential gear cluster explodes.
The race fans aren't as likely to get hit with shrapnel if you get the 12 bolt.
I think the same gears fit in either one and it is my understanding that they are interchangeable.
Haven't worked on a car in years but I use to be a smog tech. And I have built 3 Camaro's so far. Two 67s and One 68.
Stopping by this web site has got me going on Camaros again. Thanks.
I just wrote a whole page explaining the performance issues throughout the automobile.
I'll post it later along with my favorite Camaro race story.
Good luck with your Camaro.
I just typed positraction into the msn.com search engine and found tons of resources that could help answer your questions.
dioncia is offline
post #5 of 6 (permalink) Old Feb 11th, 01, 05:01 AM
12 bolt internals and 10 bolt are not interchangeable. Maybe some shims, bearings and seals but not much else. The axles are different also.
1st & 2nd GENGuy is offline
post #6 of 6 (permalink) Old Feb 11th, 01, 01:36 PM
10 bolt ring gears use ten bolts to mount ring gear,12 bolts use....... twelve bolts.The diameter of the ring gear is also different,8.250(?) & 8.875.
68L30 is offline
