used aluminum head inspection - Team Camaro Tech
post #1 of 3 (permalink) Old May 3rd, 00, 12:09 AM Thread Starter
I'm going to Canfield this weekend to the swap meet. Does anyone know what to look for when buying used aluminum heads? I am looking for Dart B.B. for my 69 camaro.
scotty dog is offline
post #2 of 3 (permalink) Old May 3rd, 00, 03:48 PM
You'd need to Dye penetrant them to check for cracks but the seller probably wouldn't appreciate that. For sure take a straight edge to check for straightness.
74 Camaro
Canada, eh!
Crash is offline
post #3 of 3 (permalink) Old May 3rd, 00, 04:57 PM
There are a bunch of things to look out for. Improper machining is the most important. Valve seats should be inspected for proper width and depth. Spring seats should all be the same depth. To measure these two areas you need a spring installed heigth gage. It basically is a unit that sits where the spring would. This is a lot of work to check and a seller at a swap meet may not want to bother. Poor porting should also be looked for as well as pulled threads in all bolt holes. Basically everthing that serves a function needs to be inspected.
Joseph
Joseph is offline
