68 RS Actuators...help!! - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 17th, 01, 03:13 AM Thread Starter
I am three weeks away from completing a three year project, installed aftermarket headlight actuators and they will not work. They bind and you can hear air leak past. I'm sure others have run across this. What are my options. If I could find newe GM for less than national debt, I would buy them. Does anyone know of a reliable aftermarket 68 RS Actuator?
Dan chilla
68RS 327
68Coupe 327
Dan Chilla is offline
post #2 of 7 (permalink) Old Jun 17th, 01, 06:06 AM
Carl
You may want to perform a site search on this subject. It has been discussed before.
There were several sets recently on ebay for $300+.
The aftermarket ones are spotty. You need to bench test before installation and return/exchange the bad ones. There is only one manufacturer for the repro part. They seem to work OK once some functional ones are found.
Good luck.
The Red Beast http://www.geocities.com/casanoc
CarlC is offline
post #3 of 7 (permalink) Old Jun 17th, 01, 07:11 AM
Jonesy's Avatar
For NOS pair try $500 +.
If you can get em cheaper buy them!
There is a pair for sale for a little over
$400 but they have not met reserve.
There was a post about the repos being junk
and that there was a new corrected repo
that worked better. Try doing a search on
this subject here and you may find the post.
Jonesy is offline
post #4 of 7 (permalink) Old Jun 17th, 01, 09:11 AM
I have to buy at least one new actuator. How do you bench test a it and my old one?
Roy
69 Firebird
68 RS TPI Camaro (in process)
mrfixit58 is offline
post #5 of 7 (permalink) Old Jun 18th, 01, 05:24 AM
Plug off on side pull a vacum and see if you lose any of the vacum. You can get a hand pump from Eastwood and I do beleve from Sears.
TIM
Tim Meredith is offline
post #6 of 7 (permalink) Old Jun 18th, 01, 07:40 AM
Ken
I just went through this with my 68. I got new ones from D&R and they work fine as does the new relay valve I got. I think the repro manufacturer is making much better ones recently.
Winch is offline
post #7 of 7 (permalink) Old Jun 19th, 01, 07:03 PM
Cool
I got mind at B and S Camaro parts in Ma. So far no problem. I've had them for 2 years. The # there is 508-673-9402. His name is Bob. Good luck. Andy
andy68rs is offline
