console temp gauge - Team Camaro Tech
post #1 of 8 (permalink) Old May 9th, 00, 08:54 AM Thread Starter
The console temp gauge in my 69 reads hot constantly when hooked up to the thermostat. I know the thermostat is right for the car, I think that it may be a faulty gauge. Does any one know how to test the temp gauge?
ANDREW is offline
post #2 of 8 (permalink) Old May 9th, 00, 11:48 AM
More than likely it is a faulty temperature sending unit. These fail quite often. GM still makes them for first gens but I can't recall the part number. This has happened to me twice over the last year.
Normally the sending unit will be in the driver's side head next to the #3 spark plug. Some people have them rigged up to be in the manifold instead of the head which gives you a little more accurate reading.
[This message has been edited by sr71bb (edited 05-09-2000).]
sr71bb is offline
post #3 of 8 (permalink) Old May 9th, 00, 05:48 PM
Carl
Be sure to check the ground line to the gauge. The gauge requires a ground line to use as a referance voltage. I forgot to hook up my console gauge ground when I worked on the car last week and as soon as I turned on the lights it buried the temp gauge to the max.
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #4 of 8 (permalink) Old May 10th, 00, 04:28 AM
Chris
Speaking about temp gauges. Where should the gauge read and what number does each line stand for?
'69 RS SS 396 375hp L78 Convertible, M22, 3.31 posi, deluxe interior, gauges, rosewood wheel, AM-FM,fold down seat, tilt wheel, SS wheels, console mounted 8 track player
Chris396 is offline
post #5 of 8 (permalink) Old May 10th, 00, 08:57 AM
Chris,
I have a BB as you know and the hottest mine normally gets is a little more than half way but I have a new 4 core radiator and I am running a 160 degree thermostat with clutch fan setup.
sr71bb is offline
post #6 of 8 (permalink) Old May 10th, 00, 01:20 PM
this was the answer i got when i asked: https://www.camaros.net/forum/Forum1/HTML/000872.html
To see a pic of my car, click here... pages.prodigy.net/mtbmtb/rf396ss.jpg
mike brown is offline
post #7 of 8 (permalink) Old May 10th, 00, 04:14 PM
mccorry's Avatar
Currently I am running a 180 deg. thermostat with a 7 blade clutch fan and 3-core radiator. Needle gets to 1/4 up at the highest.
mccorry is offline
post #8 of 8 (permalink) Old May 10th, 00, 04:35 PM
Carl
Yeah, it's a pain to do but you can calibrate the gauge by removing the sending unit, hang the sender in a pot of water, and use a candy thermometer to log temps. Run a length of wire from the temp wire to your workbench to make it easier. Be sure to ground the unit and the pot. I did this to verify my Autometer gauge readings.
CarlC is offline
