What headers fit 202 slant plug heads? - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 18th, 01, 04:13 PM Thread Starter
Hi guys.......i put ceramic coated hooker headers on my 202 slant plug heads........they didn't fit that great by the spark plugs and i had to put asbesto's covers on 4 of the spark plug boots.
which headers fit slant plug heads??
z/27 camaro is offline
post #2 of 13 (permalink) Old Apr 19th, 01, 12:32 PM
Billy
when i got my dart heads i had the same problem. i got a set a heddman headers and the problem is solved. As long as you have 90 boots on your plug wires.
'68 with a 355 and dart pro1 heads, deh275 comp cam, air-gap intake, th350 w/3000 stall and 3.73 gears. '69 SS with a 427 with edelbrock alum heads, comp cam, performer rpm intake, with a muncie 4-speed and 4.11 gears
68and69ss is offline
post #3 of 13 (permalink) Old Apr 19th, 01, 12:40 PM
Try Thorley tri-y's. They might fit and you get a great header!!
sympl_man is offline
post #4 of 13 (permalink) Old Apr 19th, 01, 02:03 PM
DjD
DjD's Avatar
I have World SportsmanII slant plugs and after talking with various reps that didn't want to commit to having something that would fit, I called World and they said only Hookers would fit properly... I called Hooker (Holley) and found they make a subframe #2466 that will fit my heads, PS etc. Well, I sure hope they will, anyway I ordered them just to find out they are backordered... It's been 4 weeks and they said about 6 so I don't have them yet!!!
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #5 of 13 (permalink) Old Apr 19th, 01, 08:02 PM Thread Starter
Smile
thanks guys!
post #6 of 13 (permalink) Old Apr 20th, 01, 02:44 PM
Chris
ckaram's Avatar
Exclamation
I put Doug's Headers on my 202 angle plug heads just a couple weeks ago. Great fit and clearance.
Doug is Doug Thorley BTW.
http://albums.photopoint.com/j/View?...248&p=36735341
ckaram is offline
post #7 of 13 (permalink) Old May 20th, 01, 04:40 PM
DjD
DjD's Avatar
Thought I would relight this one!! The Hookers never manifested themselves!! Problems at Hooker/Holley?? Don't know, all they say is they haven't started making them yet!!
I went with "Doug's" (Doug Thorley) D304's. Note: "Thorley's" are the old company Doug sold to his partner. The D304's are in on the driver side but are up against the steering box. Will see when the car is off the stands if it's a problem. The collector is in the way of the linkage to the shifter/ignition key lock and I had to unbolt it from it's mount points to get the header on... To get them in from the top I also had to remove the valve cover. I have to shorten the old exhaust on the passanger side before I can install the other one.. No real big problems though.
Just a last note: The Doug's took 3 days to get here after ordering them.... Anyone that works at the other place reading this?
...Dennis
"The Club"
DjD is offline
post #8 of 13 (permalink) Old May 20th, 01, 06:09 PM
I have World Products Sportsman angle plug heads, and Hooker Super Comp angle plug headers on my 67 with power steering. I had to dent the passenger side header to clear the idler arm but that was all. I bought the headers 5 years ago so they might have changed their design. There is one spark plug that is a real pain but the rest are simple.
Maxwell is offline
post #9 of 13 (permalink) Old May 20th, 01, 10:58 PM Thread Starter
Cool
DJD......do the dougs come in a ceramic coating???
Maxwell......just goes to show you that most parts men are idiots......when i orderd my hooker headers from MOPAC auto supply, i told them i had slant plug heads!!!and of course they said there wasn't any special header to fit slant plug heads!!!!
Gee and hooker makes some AND doug thorly too!! GO FIGURE!!!
post #10 of 13 (permalink) Old May 21st, 01, 05:54 AM
CJ
Cris
I used part# 376y1 on my small block '68 and they have a ton of room for angle or straight plug heads. As a bonus they have great ground clearance.
CJ is offline
post #11 of 13 (permalink) Old May 21st, 01, 06:59 AM
DjD
DjD's Avatar
Z/27 - they are coated. It was $150 over the cost of the header... CJ - is that a Doug's part number? It sounds more like a Thorley's part...
I forgot to mention that the Doug's come with bolts, washers, gaskets, and the pieces that bolt to the collector.
...Dennis
"The Club"
DjD is offline
post #12 of 13 (permalink) Old May 21st, 01, 12:51 PM
CJ
Cris
DjD - That's a Thorley #.
CJ is offline
post #13 of 13 (permalink) Old May 21st, 01, 05:47 PM
DjD
DjD's Avatar
I though so!! I almost went with them but being full length I didn't want to deal with ground clearance. You said they don't hang to low though but that was too late by then... I think these Doug's shorties will workout well!! I only have 1 bolt I can't tighten (too close to tube) and I am going to get a longer bolt with a metal sleeve to place the head out where it can be reached...
...Dennis
"The Club"
DjD is offline
