serpentine pulleys - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 12th, 01, 03:24 PM Thread Starter
i wanted to ask you all if it is wise to switch to a serpentine pulley set up on my 69 or just stick to the v belt set up. I went to zoops.com and all i saw there was a pulley set for a short waterpump, my car has a long water pump does this really matter? My car has a/c and power steering. I need to buy my vintage air kit first then move on to the pulleys from there. thanks for all the help.
justin
MY FIRST 69 is offline
post #2 of 7 (permalink) Old Aug 12th, 01, 03:43 PM
HI
I have a older engine in my car, pre-80, and I put the serpintine setup from an 89 firebird onto it with no problem at all. To do it right, I should have drilled 1 more whole in the head, cuz 1 bolt 1 go in, but it has no problems so far.
Josh
Joshua Leslie is offline
post #3 of 7 (permalink) Old Aug 12th, 01, 07:52 PM
i hear a serpentine system is less likely to throw belts, and doesn't slip better...plus, the factory setups are easy to replace belt if it breaks...
novaderrik is offline
post #4 of 7 (permalink) Old Aug 12th, 01, 11:19 PM
i installed a under drive, serpentine system from march pulleys. it fit great 123, looks great and im more confident in the belt than my previous double v groover.
WWW.FOTOTIME.COM/INV/OEF697FO6E88481
68rs-conv is offline
post #5 of 7 (permalink) Old Aug 13th, 01, 02:00 AM
I have a March setup.Looks and works great.
Brian.
asumtoy540 is offline
post #6 of 7 (permalink) Old Aug 13th, 01, 06:08 AM
I went with march also for a B/B.
They said that you would need a long nose for the serp. setup.
502 Bob
69 Z-502
Body by Fisher and Customized by Fisher
www.mobiletools1.com
mobiletools is offline
post #7 of 7 (permalink) Old Aug 13th, 01, 09:17 AM
Zoops does make kits for long water pumps as well. I have the v-belt short pump kit and it went on great and adjusts very easily. I got it because I want to add AC later and I already had the short pump. I also checked into buying a March kit once but Mr. March himself sent me an e-mail saying that his company does not make v-belt kits. I found that funny and sent a response with part numbers for some v-belt kits of theirs in Jegs. He never responded back so he didn't need my money.
68 RS, Ash Gold,pwr brakes,pwr windows,Hounds tooth,355/T350,MSD 6AL,3200 stall Dynamic converter,3.31:1 posi,Autometer guage pod
CA420 is offline
