Z/28 Question - Team Camaro Tech
post #1 of 6 (permalink) Old May 12th, 00, 09:50 PM Thread Starter
I just got my 69 z running today alot of fine tuning tomarrow, bought it a year ago and just getting the flow to get it going for summer.
Anyway, I have had this crossram for like 8 years now. Its a single carb type and I decided to throw it on, just cause it looks cool and nostalgic.
I am having trouble with setting the timing, were there different points type distributor thickness's. Cause I cant get it to advance enough. And if i jump a wire on the cap, I cant get it retarded enough before it binds up the other way. it only moves a little amount and then it hits the intake. HeLp PlEaSe
CORNHOLIO is offline
post #2 of 6 (permalink) Old May 13th, 00, 08:19 AM
Drake
You could pull the distributor and jump it the next tooth over on the drive gear.PIA,but I think it should work.
67 RS RAGTOP # matching,
4X4 CHEVY TRUCK
67drake is offline
post #3 of 6 (permalink) Old May 15th, 00, 04:01 AM
Tim
Send a message via AIM to sixtsevnssrs
Crossram, with a single carb?
Tim
67 ss/rs, MODIFIED
Tim's Homepage
AOL-IM = sixtsevnss
sixtsevnssrs is offline
post #4 of 6 (permalink) Old May 15th, 00, 07:45 AM
Gene
Yes, a crossram with a single carb, but it's not a GM part.
Edelbrock made a crossram manifold in the 70s and early 80s. I think they quit making them. Anyway, you could get one of two different tops, one for 2x4s and another for a single 4 barrel. I have seen these intakes at swap meets before. They do look really cool, but I always wondered how well they would perform.
Cornholio, the distributor body doesn't have to be installed in any particular position, as long as the rotor is properly indexed.
I suspect you will have a problem with poor fuel distribution once you get your engine running. As I mentioned above, I've seen these intakes before (with the top removed) and they were clearly designed for two carbs.
Hugger Orange & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 4/5/00 at:
www.geocities.com/gheatly
[This message has been edited by gheatly (edited 05-15-2000).]
gheatly is offline
post #5 of 6 (permalink) Old May 15th, 00, 08:51 AM
Bruce
Tthis is off the subject, but offenhauser made a crossram that also had the changable tops, from single to dual carbs.
i agree with gheatly. check to make sure your rotor is indexed right.
one more thing. once the car is running, make sure you don't have any vaccum leaks between the lid and the base. i've heard they can leak. make sure you check that the bolts are tight, that hold the lid down, every once and a while. or you could even add lock-tite to them. just thought i'd add that.
good luck,
bruce
bruce69camaro is offline
post #6 of 6 (permalink) Old May 17th, 00, 06:38 PM Thread Starter
Whew, finally. I tried four different distributors points, mechanical advance dual point, MSD, and some other my freind had. I had to take the grinder to the MSD, and make it work. But its done, Thanks all for help.
