Need help pulling "heater core" in a 69... - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 13th, 01, 03:28 AM Thread Starter
Can someone please tell me how to get the "heater core" out of a 69? Please see the pic, URL below, to see what I am referring to. I don't see how the unit comes out.
Also, is this unit for A/C?
Thanks,
Rob
URL: http://www.rmfsys.com/camaro/images/heater_core_1.jpg
RFrenette is offline
post #2 of 7 (permalink) Old Aug 13th, 01, 03:42 AM
The heater core does not come out through the firewall side, it comes out from under the glove box inside the car. And in regards to whether or not your car has/had A/C-the answer is no. It appears you had just a heater in your car. Hope this helps.
Go69 is offline
post #3 of 7 (permalink) Old Aug 13th, 01, 06:30 AM
Guess
HwyStarJoe's Avatar
Go69 is right. It comes out when you remove the heater box from under the dash. Pull the hoses off first. Then it's just held in to the heater box with a couple clips. You'll be surpized what you'll find behind the core!
HwyStarJoe is offline
post #4 of 7 (permalink) Old Aug 13th, 01, 06:41 AM Thread Starter
Talking
Hopefully there will be A LOT of $$$ behind there cause' I'm gonna' need it when I start to put her back together!
Thanks!
post #5 of 7 (permalink) Old Aug 13th, 01, 11:01 AM
Talking
I would also suggest putting a nice piece of plastic or some old towels over your carpet before you do any core pulling as you are bound to stir up some goop and fluids.
Toby T. is offline
post #6 of 7 (permalink) Old Aug 14th, 01, 08:52 AM
Eric
Try this message. There's a little info on loosening the heater box (engine compartment side) that you might find useful.
https://www.camaros.net/forum/Forum1/HTML/004941.html
Hope it helps
Eric
Eric68 is offline
post #7 of 7 (permalink) Old Aug 15th, 01, 02:51 AM Thread Starter
Thumbs up
Thanks for the info fella's! You guys are great!
Later,
Rob
