heads - Team Camaro Tech
post #1 of 10 (permalink) Old May 14th, 00, 10:30 AM Thread Starter
I have a 67 camaro with a 327 not original engine. block # VOI05MF any help on where it came from, the # on the heads from front to rear are 3876775 GM14 L216 thanks
camnut is offline
post #2 of 10 (permalink) Old May 14th, 00, 11:32 AM
http://www.mortec.com/castnum.htm
lists the heads as:n 3876775....1960-67...283/327 ci
sorry, that's all i found. sure someone else will help.
To see a pic of my car, click here... pages.prodigy.net/mtbmtb/rf396ss.jpg
mike brown is offline
post #3 of 10 (permalink) Old May 14th, 00, 03:55 PM
Engine code for 67 Camaro 327 two barrel carb with powerglide trans. and AIR pump system. Heads date code may be correct for the 67 year also.
tom3 is offline
post #4 of 10 (permalink) Old May 14th, 00, 07:51 PM
You sure this isn't original engine? what is build date on Trim Tag?
My Chevrolet by the Numbers (by Alan Colvin) lists the heads as being Camaro 327 / 210 hp
The L216 translates to Dec 21, '66 - - which is in line with your motor build (01/05)
I'd expect a Trim Tag build date of 01C or 01D
Dobek is offline
post #5 of 10 (permalink) Old May 16th, 00, 02:31 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by Dobek:
<HR></BLOCKQUOTE>
trim tag reads 01B D first line. ST 67-12437 NOR 70410 BODY on second line. TR 741-Z C-C PAINT on third line. 2G 3D on fourth line. tag on door pillar reads 123377N170374. found a number under the cowl vent 7L133558 maybe this will help thanks.
camnut is offline
post #6 of 10 (permalink) Old May 16th, 00, 05:19 PM
Joe
looks like engine is probably original.
01B=2nd week of Jan. 67 build date
D=Red interior
741= REd standard buckets
Z= custom bucket seat apoinments (deluxe)
CC=Ermine white paint
2G=center console
3D= ? not sure none of my books have this could this be B or D?
68 Ash gold RS 327
factory AC,PS,PB
P-O-P
joe68rs is offline
post #7 of 10 (permalink) Old May 16th, 00, 08:49 PM
CRG lists 3D as "LAMP COURTESY" which was RPO U29.
http://www.camaros.org/numbers.shtml#67Codes
Dobek is offline
post #8 of 10 (permalink) Old May 17th, 00, 03:57 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by joe68rs:
D=Red interior
2G=center console
<HR></BLOCKQUOTE>
original color of car is nantucket blue met. this is the color that showed up when I took the interior out, and the same color inside doors, fenders, trunk ect. had white vinyl top, console, standard black int. and factory air,
thanks for help keith.
camnut is offline
post #9 of 10 (permalink) Old May 22nd, 00, 10:00 AM
Am I mistaken or does he have 2 different vin #s posted above. One was taken from the door and the other under the cowl vent panel. It seems like one is a L for LA and the other is a N code for norwood.
steve
ssmoore is offline
post #10 of 10 (permalink) Old May 22nd, 00, 10:51 AM
Joe
something is wrong. looks like someone may have changed the trim tag. for car to be nantucket blue the paint code should be DD with a 1 next to it for white vinyl top. for black standard interior should be 760. post a new topic under Tag Team with all this info(cowl tag,vin#s,and the information you have already determined, nantucket blue paint,etc.). someone there maybe able to help, specifically Kurt S. with camaros.org. he maybe able to look up the Vin in his database. joe
68 Ash gold RS 327
factory AC,PS,PB
P-O-P
joe68rs is offline
