'69 Headlight Bucket Pics - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 12 (permalink) Old Jan 27th, 08, 03:46 PM Thread Starter
Hello,
Does anyone have any reference pics on how the spring in the headlight bucket attaches?
I pulled mine apart several months ago, and cannot remember the orientation.
Again, I am trying to put the small bucket that the headlight sets in back into the larger bracket.
Thanks!
Keith
awsm502 is offline
post #2 of 12 (permalink) Old Feb 1st, 08, 02:56 PM Thread Starter
Re: '69 Headlight Bucket Pics
Anyone?
How about just a pic where the spring attaches to the small bucket?
Thanks!
Keith
Keith
'69 RS/SS Camaro 502/TH400/4.11 Best 12.10 @107mph
'69 Z/28 Clone 383/TH400/3.73 Done! 996 Points out of 1000 at MCACN 2009
'72 Chevelle 540/TH400/4.11 Best [email protected] 137mph - 11/07/10
awsm502 is offline
post #3 of 12 (permalink) Old Feb 1st, 08, 03:00 PM
click's Avatar
Keith, I dont have pics of that close up but Im sure the AIM has a cutaway showing where all the parts go. If you dont have it, you need it. Assembly Instruction Manual. Available at most resto parts places and ebay.
click is offline
post #4 of 12 (permalink) Old Feb 1st, 08, 04:22 PM
madmax87's Avatar
Is this what your looking for.. The spring doesn't attach to the small bucket. It attaches to the retaining ring of the headlamp
madmax87 is offline
post #5 of 12 (permalink) Old Feb 3rd, 08, 11:07 AM Thread Starter
Thanks guys!
The AIM doesn't show the detail of how the bucket itself is assembled.
The other end of the spring attaches to the stainless ring? Man, I don't remember that. Any pics of the actual assembly would be great. Anyone have any on their resto pages?
Keith
Keith
awsm502 is offline
post #6 of 12 (permalink) Old Feb 3rd, 08, 02:37 PM
madmax87's Avatar
Ok, this is gonna cost you a beer.
Outer assy with adj scrrews attached.
Inner bucket slides into adj screws
Spring not attached yet
Lamp and ring mounted. Spring gets attached to ring only.
Final assy.
I slide the ring onto the spring and then slide the ring over the lamp and then bolt the ring in place. The spring is only used to apply pressure on the 2 adj screws.
If your headlamp does not line up with the writing on the lamp nice and straight from the front, you have the 2 inner bucket turned around. There is a difference between the 2. The inner buckets have 3 indentations in them that the lamp fits in.
Hope this helps........
madmax87 is offline
post #7 of 12 (permalink) Old Feb 11th, 08, 11:19 AM Thread Starter
Dennis,
Thanks for taking the time to post the pics. Unfortunately, all I see are red X's!
Not sure what the problem is, I usually can see posted pics just fine.
Thanks again!
Keith
awsm502 is offline
post #8 of 12 (permalink) Old Feb 11th, 08, 01:24 PM
Gary
I see them just fine. Maybe you need to use 3D glasses.
Now if the Headlights were only T3's.........
All kidding aside, those assemblies look terrific!!! You do nice work, MadMax.
Unreal is offline
post #9 of 12 (permalink) Old Feb 11th, 08, 09:29 PM
madmax87's Avatar
Not sure why you can't see them. Must be something turned on in your computer. Sometimes you can right click on the red X and click on show pic.
Thanks Unreal, ya I'm just waiting for some HID T3 lights to come out.
madmax87 is offline
post #10 of 12 (permalink) Old Feb 11th, 08, 10:09 PM
Send a message via AIM to RamAirDave
Dennis has it covered, and the pics show up for me
The half-circle cutout in the bucket should be at the top, as pictured. I install them differently than described. I pull the spring w/ a needle-nose vice-grips into the slot in the stainless ring as the last step.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #11 of 12 (permalink) Old Feb 11th, 08, 10:14 PM
Bobby
thanks madmax for the pics, i never knew the spring attaches to the headlight retaining ring, i always thought it attached to the bucket. thanks.
69 Camaro Z/28 Rally Sport 10A of 68. 50 S with 723 int. .040 over 302 with m22 autogear wide ratio. BU 12 bolt posi.
69CamaroRT is offline
post #12 of 12 (permalink) Old Feb 13th, 08, 06:19 AM
Gary
maybe it's "supposed" to mount to the trim ring, but I'm almost positive that's not the way I did mine. I think there are a couple of tabs on the bucket for the spring, but I'd have to take the bezels off and look at it to be certain.
If you do it the way the pics show, you would have to remove the spring to replace a burned headlight. If the spring attaches to the bucket, you just have to take the 3 screws out of the trim. (and of course, you need to remove the bezel in either case)
Unreal is offline
