'69 exterior mirror question - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 15 (permalink) Old Mar 20th, 10, 05:30 PM Thread Starter
Did some 69's come with just a drivers side mirror and no passenger side mirror? Was the pass mirror part of a style option?
69 SS
69 project for my wife - SS 396, Glacier blue
JayBird is offline
post #2 of 15 (permalink) Old Mar 20th, 10, 06:01 PM
Ed
bertfam's Avatar
Re: 69 exterior mirror question
The drivers side outside rear view mirror was standard (all cars came with it), and the passengers side was a dealer installed option.
Ed
Ed B.
CRG -
bertfam is online now
post #3 of 15 (permalink) Old Mar 21st, 10, 07:18 AM Thread Starter
Is there a template to show exactly where to install passenger mirror?
69 SS
JayBird is offline
post #4 of 15 (permalink) Old Mar 21st, 10, 07:48 AM
I don't know of any template but when you do go to install it, have someone hold it in position while you are setting in the driver seat. On my 68, the mirror has to be turned all of the way in in order to be functional. If it had been mounted any further back, it would have only been good for decoration.
deerhunter is offline
post #5 of 15 (permalink) Old Mar 21st, 10, 08:57 AM
Ed
bertfam's Avatar
The mounting holes were made at the factory so you should already have them.
Ed
Ed B.
CRG -
post #6 of 15 (permalink) Old Mar 23rd, 10, 02:03 AM
Garth
Ed
....for the passenger side
Garfields Maro is online now
post #7 of 15 (permalink) Old Mar 23rd, 10, 02:20 AM
Steiner
I used a piece of manilla folder and made a template from the driver side then just reversed it for the passenger side.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 15 (permalink) Old Mar 23rd, 10, 05:53 AM Thread Starter
Thanks Steiner as I checked inside of door and their is no pre-drilled hole from factory on passenger side.
69 SS
JayBird is offline
post #9 of 15 (permalink) Old Mar 23rd, 10, 06:30 AM
Ed
bertfam's Avatar
OOPS. Sorry. I didn't read your reply. No, there won't be any holes on the passengers side.
Ed
Ed B.
CRG -
post #10 of 15 (permalink) Old Mar 23rd, 10, 07:07 AM
There are several threads here for the searching that show how/where to place the passenger side mirror. I will try to find them.
Eric
Eric Kammerer is offline
post #11 of 15 (permalink) Old Mar 23rd, 10, 11:36 AM
Boo
I think placement was an issue for most who have tried to add a passenger side mirror. If you mount it in the exact same area as the driver side it becomes almost unusable due to the angle of the mirror.
Some have found they could mount a few inches closer to the fender to offset this issue.
I also recall in one of those threads someone mentioning they found a mirror that can be mounted in the same location as driver side but is more convex to allow for wider view.
I'll see if I can find it.
EDIT: Here is the mirror they used to correct the placement issue....http://www.trophymustang.com/19689-c...vex-p-447.html
and the link from the thread....https://www.camaros.net/forums/showth...ss+side+mirror
My Ride:
1968 Camaro SS Clone
booman55 is offline
post #12 of 15 (permalink) Old Mar 23rd, 10, 05:33 PM
Fred
Mine works great, is symmetrical with the drivers side, is convex and matches the lines of first gens perfectly. Also the drivers side is a absolute bolt-in, even the remote control. But, sadly, they're from 79 second gens.
128.79mph 1.428 60'
Fred Ficarra is offline
post #13 of 15 (permalink) Old Mar 24th, 10, 07:09 AM
And I bet they stay where you set them, even if you do something crazy like open and close the door Unlike the 68-69 mirrors...
Eric
post #14 of 15 (permalink) Old Mar 24th, 10, 09:46 AM
Boo
There's a fix for that, I found it out watching the Dukes of Hazzard.
My Ride:
booman55 is offline
post #15 of 15 (permalink) Old Apr 8th, 10, 10:07 AM
Boo
Re: '69 exterior mirror question
I installed my passenger side mirror (w/convex) that I got from a Mustang parts dealer. (I know ). It was an exact match as the driver side, so much so that I'm going to replace the pitted out driver side now.
It was an easy install, measured and drilled two small holes and tightened up two screws for the bracket and one screw for the mirror. Snug as a bug and mirrors stay positioned.
I posted a link earlier to Trophy Mustang, I think they are on backorder there, but I found the same mirrors at Stang-a-holic.
http://stang-aholics.com/MainCategory/Mirrors.aspx
My Ride:
booman55 is offline
