Subframe Body mount bolt just spins - Team Camaro Tech
Body Shop Paint & Body Forum
 6Likes
  • 1 Post By dhutton
  • 2 Post By Just 1 More
  • 2 Post By 67sc
  • 1 Post By USN1969SS
post #1 of 13 (permalink) Old Jan 7th, 19, 04:10 PM Thread Starter
Frank
There's always that one bolt.. Got the other 5 out and replaced, no problem.. Passenger side rear subframe bolt rusted solid, bolt was seized up.. impact and breaker bar finally got it moving but it just spins. The upper nut apparently has broke loose from it's fixed position.
What now?
Pretty sure I need to cut a hole in the floor board under the seat area to get to the top of it. I pulled the carpet and insulation back but didn't see it so i'm assuming it's sandwiched in there somewhere.. I'm disgusted right now
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 13 (permalink) Old Jan 7th, 19, 04:14 PM
Re: Subframe Body mount bolt just spins
You can access it from a slot in the seat pan. I did it years ago. Took a bit of cussing but it worked with a big open end wrench after prying off the cage. Apply lots of Kroil or something similar. You will have to remove the seat and pull back the carpet.
Just 1 More likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 13 (permalink) Old Jan 8th, 19, 07:20 AM
Patrick
Here is a photo of what Mr. Don is talking about. The photo below shows a bolt going through the captive nut from the top. A regular car is not that way. My seat perches are for a convertible.
You can see the square piece of metal, under the seat perch, that you are going to have to grab to hold the nut. The square piece is the part that is spinning.
[IMG]seat brace 14 by Patrick Smith, on Flickr[/IMG]
You picked the hardest one to have problems with.
Money can't buy you happiness but it can buy you car parts which is bout the same thang.
Patrick
tp_smith is offline
post #4 of 13 (permalink) Old Jan 8th, 19, 09:15 AM
Having torches makes rusted hardware removal easy. You bent the tabs that retain the captured nut. If you don't think you can easily get at the nut, just slice out the portion of the seat pan above it, do your work and weld the little piece back in. This is not a difficult repair.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #5 of 13 (permalink) Old Jan 8th, 19, 09:18 AM
Darin
ilikeike's Avatar
Once you have access to it,the usual places sell new cage nuts if you want to replace it. I had to do one at the firewall, that was a pain in the ...
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #6 of 13 (permalink) Old Jan 8th, 19, 10:40 AM Thread Starter
Frank
It fought me pretty good.. even after soaking it with PB Blaster,, no budge.. I cut away a small area above the caged nut, removed the cage and still couldn't get it to break loose.. Had to resort to cutting the head off the bolt and pulling it up through. I don't have access to a welder at this time so it'll go back together with a good thick oversized washer and a lock nut with anti-seize on the threads.
I cleaned the area as best I could then sprayed it good with Eastwoods Rust Encapsulator, top, bottom, inside, outside.. everywhere I could.
20190108_104536 by F G, on Flickr
dhutton and pittpens24 like this.
'68 Camaro 454, 4sp
post #7 of 13 (permalink) Old Jan 11th, 19, 05:48 PM
Eldon
That looks like a complete PITA. Glad you got it out.
Elrodeano Vanfan is offline
post #8 of 13 (permalink) Old Feb 2nd, 19, 11:51 PM
Eldon
I just got to deal with my own cage nut spin syndrome. It was front passenger at the firewall. I ended up cutting the bolt with a saws all. I will have to weld a nut on to the broken stud and secure the cage nut and try to get it out of there. Before I tackle that I'm dropping the rear end. Fighting with the clip nuts right now.
post #9 of 13 (permalink) Old Feb 3rd, 19, 11:06 PM
Kev
Bolts jam on nuts because the threads get clogged with rust and junk. The key is to loosen a bit, tighten a bit, and repeat. I like a 3/8" breaker bar so I don't have to reverse the ratchet and it doesn't allow much torque. Lots of lube is also vital. Of course, it's a bit late in this case...
This sort of basic common sense is typically ignored so I imagine few will absorb the concept.
pittpens24 and Niblet like this.
67sc is offline
post #10 of 13 (permalink) Old Feb 4th, 19, 05:56 AM
Vega$69's Avatar
X2. Often guys just get a bigger breaker or impact wrench. To help with the body bolts actually tighten a little 1st then back and forth with use of PB or WD. The threads exposed above the nut cause it to lock up when you try to back it out so the tightening a little allows the lube to travel into the threads of the nut.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #11 of 13 (permalink) Old Feb 4th, 19, 06:33 AM Thread Starter
Frank
Tried that.. Didn't help in this case
'68 Camaro 454, 4sp
post #12 of 13 (permalink) Old Mar 10th, 19, 12:10 PM
USN1969SS's Avatar
X3 if your not in a rush. This was the middle passenger bolt, took about a week of spraying and turning back and forth. I would spray it, let it sit, do minimal turns, spray it again, spray next morning, spray after work, minimal turns and repeat process. After about a week it was able to turn without fear of breaking.
53Crestline likes this.
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
USN1969SS is offline
post #13 of 13 (permalink) Old Mar 11th, 19, 05:43 PM
Once you've figured out the repair, use antiseize on the new threads.
You'll appreciate it later in life.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
