67 SS Nose Stripe - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 5 (permalink) Old Feb 28th, 19, 10:39 AM Thread Starter
Dale
67 SS Nose Stripe
I know there is lots of forums and info out there. It's tough to take it all in because some of it contradicts itself. I post these questions before and got a few answers but not all of them.
1. What is the size of the actual "SS" badge?
2. Is the badge centered between the large stripe with the 9/16 and 1/2 spacing and 1/2 and 9/16 as mentioned before?
3. Is the "SS" badge centered off the headlight?
4. Pending on build date is whether or the stripe stops at the bottom of the bumper or continues past it to the end of the panel?
5. What are the correct measurements for the "chevrolet camaro" emblem on the top outside nose area that goes somewhere in the stripe?
First stripe ???
- .83 from the front on outside and slightly tapers into .75 in the center.
- Stripe width is .10
- Spacing is .12
- Large stripe width is 3.75
- Spacing is .12
67 Camaro
Wigman87 is offline
post #2 of 5 (permalink) Old Feb 28th, 19, 11:04 AM
Re: 67 SS Nose Stripe
4) yes although I don't recall the approximate date change.
5) your answer is in this thread. https://www.camaros.net/forums/34-re...l-emblems.html
Yes on the dimensions. Follow the rest of the AIM dims for the fender peak and wrap around.
my 67' build thread:
allanjs is offline
post #3 of 5 (permalink) Old Feb 28th, 19, 02:45 PM
Roger
rogerh's Avatar
1. One S is 1" tall X 1 13/16" wide
2. I believe they look better centered to the strip but that is hard to do. The Assembly Manual has the dimensions below, where they are located.
3. No the headlight has nothing to do with it. The SS emblems are located about 1/8' to 3/16' above the center break of the fender. That may be covered in the Assemble Manual dimensions but it's hard to tell.
4. I am not aware of the build date where they shorted the strip. I do have pictures of some 67 Indy Pace Cars and they have the shorter strip so it was before May.
5. This thread will answer this question.
One problem I have seen is the rear line of the strip, below the SS or RS emblems should NOT go straight down. That line should break to the front, ever so slightly to make it appear it keeps the dimension of the strip going around the finder curve.
Roger
ID:	225331   Click image for larger version
rogerh is online now
post #4 of 5 (permalink) Old Mar 1st, 19, 06:35 PM
Tom Anderson
Those SS emblems are hard to put on , I did mine and I would not want to do it again . drilling into new paint you only get 1 chance to get it right
socal_tom is offline
post #5 of 5 (permalink) Old Mar 1st, 19, 08:13 PM
You can cut the posts off the emblem and use 3M emblem adhesive if you don't want to drill for the emblem posts
Self stick emblems may be available also
SoCal805 is online now
67 Bumble Bee Stripe? SoCal805 Body Shop 9 Mar 5th, 19 10:17 AM
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 07:32 PM
Can I keep my factory A/C in my 67 if I drop in a '67 BBC? Niblet Heating & Cooling 10 Nov 5th, 18 02:26 PM
67 camaro rs / ss header stripe question Cmonson Restoration Corner 4 Sep 21st, 18 08:11 AM
