Outer wheelhouse to trunk dropdown - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 4 (permalink) Old Mar 17th, 19, 09:25 AM Thread Starter
michael
I'm working on welding the outer wheelhouse and trunk dropdown on, however there is a gap between the two. Is there supposed to be a gap or are they meant to be connected together?
Mikey10000 is offline
post #2 of 4 (permalink) Old Mar 17th, 19, 08:07 PM
Re: Outer wheelhouse to trunk dropdown
The arch should be tight to the wheel house and spot welded.
my 67' build thread:
allanjs is online now
post #3 of 4 (permalink) Old Mar 18th, 19, 05:44 AM
Patrick
Test fit the quarter panel. The shape of the outer wheel house might change when you fit the quarter panel. I had the same problem as you. I had the same gap between the drop off and wheel house. My gap between the drop off and quarter panel was also too wide.
Fit it to the trunk pan, wheel house, and quarter panel to the drop off before welding anything. I used sheet metal screws to temporarily hold everything together.
Patrick
tp_smith is offline
post #4 of 4 (permalink) Old Mar 18th, 19, 11:24 AM Thread Starter
michael
Thanks, good idea on the quarter panel fit too. I have been using the screws to hold the wheelhouse before i weld it.
AMD trunk pan, cutouts and stampings general23cmp Body Shop 9 Jan 31st, 19 09:56 AM
Outer Wheelhouse Help Legeance Body Shop 3 Jan 25th, 19 11:44 AM
Quarter panel / outer wheelhouse lip attached? general23cmp Body Shop 20 Oct 17th, 18 04:29 PM
Rear inner wheelhouse attachment points general23cmp Body Shop 7 Sep 30th, 18 06:04 PM
Wiring harness routing in the trunk ??? daven1256 Camaro Tech 8 Nov 23rd, 17 06:58 PM
