Panel epoxy primer question - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 6 (permalink) Old Mar 21st, 19, 11:14 AM Thread Starter
michael
I have sanded down the undercoat and paint from the inner wheelhouse, and will scuff or remove the edp coating from the underside of my new outer wheelhouse. The question I have is, should I just paint those and any hidden interior surfaces with an epoxy paint to seal them or use something else? If so what brand on epoxy primer should I get? What kind of surface prep would I need, remove all loose rust or apply a rust killer first?
My build thread
Mikey10000 is offline
post #2 of 6 (permalink) Old Mar 21st, 19, 12:25 PM
Travis
Re: Panel epoxy primer question
If its not a factory correct restoration then I'd use a direct to metal product. I used Chassis Saver on mine and the results were great. Its damn tough stuff and looks good.
travisch is offline
post #3 of 6 (permalink) Old Mar 21st, 19, 12:27 PM
Steven
stamatisg1977's Avatar
I use SPI epoxy
Scuff hard to reach areas with a red scotch brite
The rest can be done with 80 grit on a DA or by hand
Wire wheel any rust or spot blast
Clean real good let dry for 30 min and shoot epoxy
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #4 of 6 (permalink) Old Mar 24th, 19, 12:43 PM Thread Starter
michael
That actually sounds pretty good, but I was trying to give it more of a factory correct build, at least that's the plan for now!
My build thread
post #5 of 6 (permalink) Old Mar 24th, 19, 12:46 PM Thread Starter
michael
I think that's what I will do, I just need to find somewhere that sells it.
Originally Posted by stamatisg1977 View Post
I use SPI epoxy
My build thread
post #6 of 6 (permalink) Old Mar 24th, 19, 12:58 PM
Call and order it direct with free shipping.
Southernpolyurethanes.com
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
quick epoxy primer advice 67SS/RSCONV Body Shop 9 Dec 23rd, 18 06:12 AM
Sand epoxy primer DT Body Shop 9 Nov 24th, 18 03:37 PM
Vintage Air Kick Panel Modification ssanto Heating & Cooling 4 Nov 22nd, 18 05:08 PM
Question on OEM Fuse Panel 57vette Electrical & Wiring 7 Jun 5th, 18 07:15 PM
Sail panel bulge at end of drip rail ssanto Body Shop 4 Dec 30th, 17 04:11 PM
