Methods for attaching RS Fender Adapters - Team Camaro Tech
Body Shop Paint & Body Forum
 8Likes
post #1 of 43 (permalink) Old Apr 13th, 19, 08:28 PM Thread Starter
I'm finally moving along with my RS front end conversion, and I'm curious about those people who have added an RS grill and used the tabbed fender adapters that allow you to mount the motorized buckets properly. I'm using the Camaro Central Stage 3 Kit, where the entire bucket/headlight assembly comes all set up and pre-tested... all you do is mount the bucket, connect the module & wires, and its supposed to work.
But the question I have is all about the adapters... the existing fender tabs are factory spot-welded, and the new brackets have matching tabs that align and nest with the existing fender contour. Different people have suggested different methods:
1. Just bolt the tabs together with a pan-head SS machine screw, a couple of washers, and a nylon lock nut.
2. Spot/Tack Weld all three tabs which is probably OK for a project in works car.
3. Use 3M Panel Bond on the tab mating surfaces after sanding off the paint, and then bolt or rivet the bracket to the fender.
In the case of #3, some people have sanded inside the fender "nose" and also bonded the entire 7 or 8 inches although there's nothing clamping the two pieces other than maybe a couple of temporary clamps until it cures.
So what have YOU done? What is overkill, and do you think just bolting it together with locknuts is sufficient? I read that article from Super Chevy when they did the conversion with this kit and they just bolted it together. After all, most of the car is just bolted together LOL. Pardon the extra long 8-32's in the pictures... I just grabbed what was handy as they don't include screws with the kit.
ID:	226449   Click image for larger version
ID:	226451   Click image for larger version
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #2 of 43 (permalink) Old Apr 13th, 19, 09:27 PM
Vega$69's Avatar
Re: Methods for attaching RS Fender Adapters
Rivets work well
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 43 (permalink) Old Apr 14th, 19, 07:21 AM Thread Starter
Originally Posted by Vega$69 View Post
Rivets work well
Hey John... Have you used rivets with these brackets? Just curious bc the diameter of the bracket holes is larger than the OEM fender tab holes so if I used machine screws a washer is necessary.
All I've got is a pop-rivet tool, would that work with a washer, kind of like a small fender washer? Or do I need some exotic rivet tool for these six spots?
57vette is offline
post #4 of 43 (permalink) Old Apr 14th, 19, 07:27 AM
DT
Donny
DT's Avatar
3M panel bond adhesive
DT is offline
post #5 of 43 (permalink) Old Apr 14th, 19, 10:28 AM Thread Starter
3M panel bonding adhesive where? The tabs? Or the entire sides inside the fender? I was thinking 3M, but I'm wondering how the buckets can move when you have two huge 5/16" bolts on the back and two more mounted to the adapter which is bolted or riveted to the matching fender tabs.
Which method did you use and why?
57vette is offline
post #6 of 43 (permalink) Old Apr 14th, 19, 11:04 AM
DT
Donny
DT's Avatar
I haven't done mine yet, but my plan was to use 3M panel bond adhesive on the sides, inside the fender. I'm impressed with this stuff. I used it previously and was thoroughly impressed with its strength.
DT is offline
post #7 of 43 (permalink) Old Apr 14th, 19, 05:22 PM Thread Starter
Just a heads-Up Donny... don't permanently attach them until you have fitted them completely with the grill in place after you get them working. I put the 2nd bucket in this afternoon and then unpacked the grill to see how it would fit. It didn't LOL. I think I'm going to go at this a little different. Maybe pull both buckets out and see what the grill fits like. I already know there's a interference spot on the extreme corner of the upper PS valance where the fender connects... I'm going to have to grind down the raised edge to get rid of the interference. Also, I'm going to to set the buckets back a little more by elongating the lower tab holes because the grill is hitting the outside passenger side of the bucket frame. Might be able to tweak the grill a little before paint... and paint is the last thing on my mind right now. I already used a step drill to open up the two bucket locator holes on the radiator support wall. Did that to allow some jiggle in aligning the bucket, will use fender washers to lock it up when I find the sweet spot.
One last thing I'll share... is page 3 of the instructions in its entirety LOL.
57vette is offline
post #8 of 43 (permalink) Old Apr 14th, 19, 05:46 PM
DT
Donny
DT's Avatar
Omg here we go!
57vette likes this.
DT is offline
post #9 of 43 (permalink) Old Apr 14th, 19, 05:54 PM
Everett is going to have to add that instruction page to his humpday humor joke list as that had me laughing as much as any of his jokes. Absolutely hilarious!!!😁😁😁
57vette likes this.
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #10 of 43 (permalink) Old Apr 14th, 19, 10:35 PM Thread Starter
Dave... The instructions as many other have said... leave a lot to be desired. They do tell you to read the Super Chevy article, which has some pictures but not a whole lot about the details of the install. But when I saw that page I literally groaned and then started laughing.
I will say that the pre-assembled and tested buckets are really nicely made. And as far as the install, we'll I guess that's why that page was in the box. There's going to be a lot of tweaking, but eventually it'll work out. I hope!
DT likes this.
57vette is offline
post #11 of 43 (permalink) Old Apr 15th, 19, 03:38 PM Thread Starter
So I pulled both buckets today, also the brackets, trying to test fit the grill shell. Still have the high spot mentioned earlier where the 4th tab is just under the header where the stiffener nests. I'll deal with that later. pushing in as much as I could/dared (and I don't want to stress the part) the "V" in the center is out about 1/2" so I decided to compare new and old.
Laid them on my pool table and weighed down the opposite end so that both flanges were dead even. Went over and measured the difference at the opposite end... its a good healthy half an inch, maybe 5/8". So maybe this piece came out of the mold warm and didn't cool off at the exact angle. I know some guys have used heat guns to alter the contours of the flanges on these '69 grills, but I'm wondering if I should attempt to heat up the center a little and gently push on it to see if I can "spread" the grill a little so there's no stress on it when its bolted to the lower valance?
57vette is offline
post #12 of 43 (permalink) Old Apr 15th, 19, 04:17 PM
Did you buy a repop grille or a GM part? The original grille is still available from GM.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #13 of 43 (permalink) Old Apr 15th, 19, 06:23 PM
Donnie
I used sheet metal screws to fasten them and then bent, shimmed with washers as needed. The screws never came loose and nothing ever moved after being fit to there they needed to be and then screwed tight.
Camaro Donnie
1969 RS/SS Black 4 Speed Camaro Coupe
390 Gears with 410 CI small block
Camaro Donnie is offline
post #14 of 43 (permalink) Old Apr 16th, 19, 01:11 PM Thread Starter
Donnie... Are you talking about the buckets or the grill? If its the buckets, I'm thinking its best to start with the two rear bucket bolts, space the bucket out about 1/2" and since the holes are oversized and fender washers are on both sides of the bulkhead, you should be able to move the buckets to fit the grill opening once you get the grill to seat properly. I'm attaching a picture of what one guy did to space the buckets, used oversized bolts as a spacer. Weird, but he claims it worked.
57vette is offline
post #15 of 43 (permalink) Old May 6th, 19, 11:26 PM Thread Starter
Been pulling my hair out for a week trying to get the RS buckets seated properly. The gearboxes are hitting the radiator support and I'm reluctant to cut up the support to try and make it work. See pix for details.
Was wondering if a couple of people could measure the distance from the firewall to the radiator support on each side of the engine bay right next to the fender. Thinking maybe I could slot the support holes and push it back 1/2"-3/4" as I have room in front of the fan so the radiator could go back a little.
All I want to do is clear the grill somthe doors can swing without hitting anything.ive already put 1/4" spacers in the RS brackets to move the side mounts back, but the doors are still jamming up1/4 of the way closing and don't really fill the hole bc they're cocked.
ID:	226845   Click image for larger version
ID:	226847   Click image for larger version
ID:	226851   Click image for larger version
ID:	226853   Click image for larger version
57vette is offline
69 rustbucket rebirth 350sshugger Build Projects 1118 Feb 17th, 20 08:49 PM
1969 firebird convertible with photos tp_smith Build Projects 432 Feb 7th, 20 10:36 PM
1969 upper fender to door gap passangeer side. camaro69ss572 Body Shop 11 Jul 16th, 18 12:31 PM
I need some help, installing new front fenders and doors Mrcrsr Body Shop 8 Jan 4th, 18 12:51 PM
