Adjusting door gaps without glass installed - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 4 (permalink) Old Apr 15th, 19, 07:54 PM Thread Starter
Sal
I'm going to be hanging my doors and doing final gap alignment in a couple weeks. Can I do this without the weight of the glass or should I strap 30 lbs into the door? I'm worried that after I install the glass, the door will sit differently and mess up the gaps.
I have original hinges that have been rebuilt.
One other question... my drivers side door hinge makes a clunk or a pop when I open it. This was when I had installed the hinges but not yet greased them up. It's taken apart now and I won't be able to check and see if grease helps until after I put it back togheter. Not sure if this is expected or common or if there is something I could do about it.
Thanks,
Sal
ssanto is offline
post #2 of 4 (permalink) Old Apr 16th, 19, 05:41 AM
Kevin
KevinW's Avatar
Re: Adjusting door gaps without glass installed
Yes, put weight in the door when adjusting. The clunk may be the spring part.
Kevin
KevinW is online now
post #3 of 4 (permalink) Old Apr 16th, 19, 06:20 AM
Steven
stamatisg1977's Avatar
The clunk is a binding detent
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #4 of 4 (permalink) Old Apr 16th, 19, 09:36 AM
30 lbs might be a bit much. I used 15-20 lbs. I had some old house window weights
I laid inside the door. That allowed the weight to be distributed equally along the
length of the door closely simulating the glass and hardware. Check the door hinge
mounting area closely for possible cracks (metal fatigue). That can cause the clunk
but it's most likely the detent as Steven said.
my 67' build thread:
allanjs is offline
My 67 Resto Mod Build Sosh67 Build Projects 291 Feb 2nd, 20 05:14 PM
Help adjusting door glass !!!!! 69crush Interiors 20 Nov 16th, 18 11:57 AM
Glass installed in So Cal?? JoeDanger Tools & Shops 11 May 14th, 18 08:24 AM
Door glass codes on my 69 Camaro SS69 L48 Restoration Corner 6 Mar 9th, 18 03:30 PM
Glass roller questions ssanto Body Shop 1 Nov 26th, 17 06:22 PM
