SEM Paint - Team Camaro Tech
Body Shop Paint & Body Forum
 1Likes
post #1 of 24 (permalink) Old May 7th, 19, 08:24 PM Thread Starter
SEM Paint
I have been looking for some old stock SEM 07034 Karrot or 24 Karrot paint. I recently had a scratch in the paint and the body shop informed me it is no longer produced and they also could not get the formulation from SEM. They were able to find 1/2 quart from another shop to do the repair. I am looking to buy more to have on hand for the next time I need it. Can anyone lead me to where I would look for a body shop that might have some they'd be willing to sell?
Thanks as always
1967 Camaro
383 stroker
Automatic
Duneit is online now
post #2 of 24 (permalink) Old May 7th, 19, 09:00 PM
Chris
Re: SEM Paint
I contacted SEM several months ago concerning a discontinued paint color and they gave me the paint code and said an auto paint store that sells SEM could mix it and either put it in a can or in an aerosol.
dyno jonn likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #3 of 24 (permalink) Old May 7th, 19, 09:05 PM Thread Starter
Re: SEM Paint
The body shop i took my car to did contact SEM and they didn't have it. I'll try calling them myself. Could be because the paint can't be sold in California any more?
1967 Camaro
383 stroker
Automatic
post #4 of 24 (permalink) Old May 8th, 19, 07:04 AM
Chris
Re: SEM Paint
Yea, that's probably it. I'm not sure how anything can be sold in CA anymore given that everything I see has a CA warning of some form or another - ridiculous.
ctcz28 is offline
post #5 of 24 (permalink) Old May 8th, 19, 07:22 AM Thread Starter
Just spoke to them. They do not offer it anymore. So if you buy SEM paint you're out of luck if you need to touch up your paint. It's been 8 years since car was painted. Wish paint manufacturers were held to same standards as automakers having to support their products for at least 10 years.
1967 Camaro
383 stroker
Automatic
post #6 of 24 (permalink) Old May 8th, 19, 08:21 AM
Beth
Re: SEM Paint
Have you tried taking the car to a sherwin-williams or dupont auto paint store and let them try to match it ?
It might take a couple of tries but they should be able to.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #7 of 24 (permalink) Old May 8th, 19, 08:25 AM
Re: SEM Paint
One of the new systems using digital color match cameras should be able to match it. They will only get better with time so if you donít need it now donít worry and wait until you do.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #8 of 24 (permalink) Old May 8th, 19, 10:54 AM Thread Starter
Originally Posted by dhutton View Post
One of the new systems using digital color match cameras should be able to match it. They will only get better with time so if you don’t need it now don’t worry and wait until you do.
The shop I took it to had the rep come out with their latest greatest paint gun and after over 20 attempts at matching they were unsuccessful.
1967 Camaro
383 stroker
Automatic
post #9 of 24 (permalink) Old May 8th, 19, 11:19 AM
Re: SEM Paint
Silver and gold are tough to match and blend. But I am pretty sure it can be done if the need ever arises. And technology continues to improve.
post #10 of 24 (permalink) Old May 8th, 19, 05:56 PM Thread Starter
Re: SEM Paint
The need did arise. Fortunately after asking around the shop was able to locate some that a motorcycle shop had that was left over. It cost me over 8K to get a scratch fixed because the paint isn't available any more. This is the response from the SEM rep.
"Hey Dave,
Since custom paint jobs are individually done, to repair a spot would require using the exact same products, ratios, number of coats, paint gun set-up and a myriad of other variables to get an exact match. Most time a new paint job is all that can be done. You should check with the painter to see what he can suggest.
Thanks again".
Their answer for a scratch is a new paint job. 25K for a paint job to repair a scratch? For all you painters out there, is this really the answer for an 8 year old paint job on a car that is always garaged and has less than 5,000 miles? Do any of you painters know where or how I would try to find some one who has some old stock? The paint shop that fixed my scratch told me the same thing the SEM rep said. Next time I will have to re paint the entire car unless I can find some old stock some one might have lying around. Any help with how to acquire more paint would be greatly appreciated.
Thanks again,
1967 Camaro
383 stroker
Automatic
post #11 of 24 (permalink) Old May 8th, 19, 08:08 PM
Chris
Re: SEM Paint
I needed to match the exterior paint on my car, old lacquer. I pulled the spoiler off the car and took it to a local auto paint supply store and they matched it perfectly. It was a bit costly since they had to mix several samples to get it right, but were successful. Based on my experience with this, you just need to find the right paint shop that is willing to do the work to match this for you. For what it's worth, what SEM told me was that even though they no longer made the particular color I needed (a dark blue I'd used over 15 years prior for my interior) they did have the code and a paint shop that sold SEM should be able to custom blend it with the color proportions provided for that particular code. Just an additional tip; if you do get a custom mix to match make sure you get the formula in case you need more and don't rely on the shop to keep the formula for you in their records. If they change computer systems the older formulas are easily lost forever.
ctcz28 is offline
post #12 of 24 (permalink) Old May 8th, 19, 08:56 PM Thread Starter
[QUOTE=ctcz28;1783137909]I needed to match the exterior paint on my car, old lacquer. I pulled the spoiler off the car and took it to a local auto paint supply store and they matched it perfectly. It was a bit costly since they had to mix several samples to get it right, but were successful. Based on my experience with this, you just need to find the right paint shop that is willing to do the work to match this for you. For what it's worth, what SEM told me was that even though they no longer made the particular color I needed (a dark blue I'd used over 15 years prior for my interior) they did have the code and a paint shop that sold SEM should be able to custom blend it with the color proportions provided for that particular code. Just an additional tip; if you do get a custom mix to match make sure you get the formula in case you need more and don't rely on the shop to keep the formula for you in their records. If they change computer systems the older formulas are easily lost forever.[/QUOTE
The SEM rep told me in an email they do not have the mix code any more. The shop tried at least 20 times to match the paint. I have all the samples they sprayed. They couldn't get it exact. It is a gold with pearl and flake in it. A beautiful deep color and an extremely difficult color to match. When I have spare time I'll start cold calling custom paint shops. I'll get more some how.
1967 Camaro
383 stroker
Automatic
post #13 of 24 (permalink) Old May 9th, 19, 04:49 AM
Re: SEM Paint
Codes are here:
Karrot Hyper Base Airbrush Spray Paints - 07034 - Karrot Paint, Karrot Color, SEM Hyper Base Spray Paint, D08436 - Art-Paints.com
post #14 of 24 (permalink) Old May 9th, 19, 05:52 AM Thread Starter
Re: SEM Paint
Don,
Thank you for trying to help, I really appreciate it. The SEM rep came out with his paint camera and couldn't match it. I would think the rep for the company would know if there was a formula that could be used. I also don't think he would go through all the effort to make all these different color swatches if it were as easy as you think it is. At this point I am just looking for advice on how to go about finding some old stock some one might have laying around.
Thank you,
Name:	Austin's paint.jpg
1967 Camaro
383 stroker
Automatic
post #15 of 24 (permalink) Old May 9th, 19, 06:10 AM
Re: SEM Paint
You are hard to please. I handed you the paint codes. Good luck with your quest for unobtanium....
Metallic gold will be a beeotch to match regardless. Gun setup and spray technique can greatly affect how the metallics lay and the resulting color.
Touchup Paint SoCal805 Body Shop 1 Aug 14th, 19 12:11 PM
Started stripping paint -Multiple layers JD4020 Body Shop 4 Mar 11th, 19 09:46 PM
Paint on the id tab and control arms old person Body Shop 12 Aug 7th, 18 08:51 PM
Touch-Up Paint & More at RockAuto.com! RockAuto RockAuto 0 Apr 12th, 18 07:40 AM
Underbody paint 327fuelinjected Body Shop 8 Mar 20th, 18 06:31 AM
