Taillight Assemblies - Team Camaro Tech
Body Shop Paint & Body Forum
 1Likes
  • 1 Post By Shannon4570
post #1 of 6 (permalink) Old May 12th, 19, 09:12 AM Thread Starter
Tim
I posted this question in my build log but didn't get any responses so I thought I would try a stand alone question. This is probably going to seem pretty remedial but I need some help with how the tail light assemblies go back together. Is this correct:
Lens fits in housing, housing sandwiches foam gasket between lens and inner tail light panel? I am asking because when I mock it up it seems like the foam gasket will be visible from outside the car? Perhaps once all the fasteners are tightened up it closes it up. I also don't understand why the taillight lenses have a nice hard rubber seal which apparently only sits against the foam gasket - seems redundant. These are all repop pieces as part of my RS conversion.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #2 of 6 (permalink) Old May 12th, 19, 11:20 AM
69-Pace's Avatar
Exclamation Re: Taillight Assemblies
If I remember right you take the housing, then insert the RS lens, then weatherstripping, then you just push as a unit the whole works against trunk body wall and bolt it on tight. The weatherstripping should seal against body. The foam over a period of time will dry rot but the rubber still holds for a while.
Edit: I just found this conversion to LEDs at superchevy so guess I'm right.
http://www.superchevy.com/how-to/add...-a-1969-camaro
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old May 12th, 19, 04:29 PM Thread Starter
Tim
Thanks, I appreciate the response. I figured it was the way they went but can't hurt to double check.
69-Pace likes this.
post #4 of 6 (permalink) Old May 13th, 19, 09:13 PM
69-Pace's Avatar
Always better safe than sorry.
69-Pace is offline
post #5 of 6 (permalink) Old May 15th, 19, 07:04 AM
Matt
In the Super Chevy article, I noticed they did not include the foam, only the rubber seal? Is the foam redundant or not even needed if the rubber gaskets are used?
Matt
1969 Nova
1969 Camaro
1973 Camaro
Follow my '69 Build:
69Nova is offline
post #6 of 6 (permalink) Old May 15th, 19, 05:07 PM
I found the foam gasket did not seal completely, try to find a pair of original rubber ones.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
Molded taillight gaskets - where to buy? daven1256 Body Shop 20 Apr 7th, 18 09:26 PM
Good quality taillight bezels Ovelarsen2000 Restoration Corner 13 Feb 11th, 18 01:53 AM
1969 camaro taillight lens Spirit1 Body Shop 16 Dec 4th, 06 05:53 PM
'67 Taillight & Turn Signal Electrical Problems macasiebjj Electrical & Wiring 3 Nov 13th, 03 06:57 PM
69 taillight harness Phil737 Electrical & Wiring 8 Jul 21st, 01 05:02 AM
