I'm not a body man... - Team Camaro Tech
Body Shop Paint & Body Forum
 4Likes
post #1 of 19 (permalink) Old May 22nd, 19, 07:24 AM Thread Starter
Frank
I can tell already,,, after wrestling the passenger side fender,,,, that i'll get everything bolted on and then take it the pro's to get the gaps right ..
You body guys must have the most patience of anyone
20190521_181522 by F G, on Flickr
wireboy355 likes this.
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 19 (permalink) Old May 22nd, 19, 09:02 AM
Re: I'm not a body man...
Me neither but you have a body. So the first thing you do is set the gaps on the door since the rear fenders are welded in place and aren't going any where. You then work your way forward to the fenders measuring off of your freshly adjusted door with a paint stick. If things don't fit from there you have bad parts not lack of skill and you must modify the part to fit the gap (break out the electric glue gun) which is where a MIG welder comes into it's own.
Big Dave
Larger Dave is online now
post #3 of 19 (permalink) Old May 22nd, 19, 09:13 AM
Greg
The alignment part isn't overly hard, but it is very time consuming. I'm sure you could handle it if you just wanted to dedicate the time to it.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #4 of 19 (permalink) Old May 22nd, 19, 09:34 AM
steve
I have had better luck installing both fenders, hood, header panel, and cowl panel. If you don't square everything up first, your adjustments could be a waste of time.
grampstoyz is online now
post #5 of 19 (permalink) Old May 22nd, 19, 09:35 AM Thread Starter
Frank
That's my plan,, get everything mounted, LOOSELY, and go from there
'68 Camaro 454, 4sp
post #6 of 19 (permalink) Old May 22nd, 19, 09:36 AM
Steven
stamatisg1977's Avatar
Worn out body bushings will make an otherwise good fitting fender a big head scratcher if you dont know what to check
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #7 of 19 (permalink) Old May 22nd, 19, 03:23 PM Thread Starter
Frank
All new solid bushings
'68 Camaro 454, 4sp
post #8 of 19 (permalink) Old May 22nd, 19, 03:53 PM
Fenders are easy.... try a door
68 Camaro~LSx ~all motor
post #9 of 19 (permalink) Old May 23rd, 19, 06:57 AM Thread Starter
Frank
I know what you mean... I rebuilt the door hinges on the drivers door and wrestled that biotch for over an hour trying to get it lined up and latching again
'68 Camaro 454, 4sp
post #10 of 19 (permalink) Old May 23rd, 19, 07:11 AM
keith
X-77 keith's Avatar
Put all 4 tires on it . then get your gaps. You would be surprised how it may differ. Even with solid mounts.
X-77 keith
X-77 keith is offline
post #11 of 19 (permalink) Old May 23rd, 19, 08:51 AM
Steven
I have these that set the door to rocker gap then i can slide it forward or back to set door to quarter gap
Then all i have to do is bolt the hinges up
ID:	227173   Click image for larger version
ID:	227177   Click image for larger version
Tremec TKO 600
post #12 of 19 (permalink) Old Jun 20th, 19, 06:26 AM Thread Starter
Frank
Starting over.. kind of.. I realized yesterday that my subframe is not squared and aligned properly. I did not know about the dowel alignment holes for the subframe and when I looked at them yesterday they are definitely not in line. I need to pull the engine to deal with some other issues so i'm going to tear it all down and start over
'68 Camaro 454, 4sp
post #13 of 19 (permalink) Old Jun 20th, 19, 09:18 AM
Frank, You don't have to remove all of the front sheet metal to align the sub frame.
Just loosen the fender to body bolts and watch the clearances. Tape edges. The sub
alignment pins are .61 diameter. Not .625 (5/8"). I used a tapered pin style pry bar
and then .61 pins for final check.
my 67' build thread:
allanjs is offline
post #14 of 19 (permalink) Old Jun 20th, 19, 09:33 AM Thread Starter
Frank
Where do you get the pins? I've got one of those round tapered pry bars but would like to have the right pins for final check. I think i'll leave the fenders in place and loosen everything real good. Going to remove the core support and front header, valance etc.. for ease of engine removal. (must remove to deal with oil pan/steering issue)
I've watched a few videos about how and where to take some measurements so i'm going to go look at that as well.
'68 Camaro 454, 4sp
post #15 of 19 (permalink) Old Jun 20th, 19, 09:52 AM
Frank, I owned a machine shop until I retired last year. We had some 15.5mm (.61 inch) round
bar stock so that's what I used. If you use a tapered pin pry bar and then verify with measurements
you'll be golden. I didn't have to move mine at all after using the tapered pin pry bar. The .61 pins
slipped right in.
allanjs is offline
Wanted: Good Body Man Seanalex95 Body Shop 1 May 20th, 09 10:37 AM
finally found a body man $35 an hour johnny67 Body Shop 21 May 5th, 09 04:33 PM
The 67 is finally at the body shop cpodeep Body Shop 6 Apr 12th, 09 11:38 AM
Body man Needed in middle GA Tom Weaver Body Shop 2 Jun 20th, 03 12:31 AM
LA car vrs NOR car allcamaro Tech 2000 22 Oct 7th, 00 02:44 PM
