spot weld bit choice - Team Camaro Tech
Body Shop Paint & Body Forum
 4Likes
  • 1 Post By pittpens24
  • 1 Post By 350sshugger
  • 1 Post By dhutton
  • 1 Post By Checkered Past
post #1 of 11 (permalink) Old Nov 22nd, 19, 03:30 AM Thread Starter
Getting ready to start replacing my floorboard in a 69 camaro - any recommendations on a spot weld bit and other approaches to cutting it out?
69 Pace Car and 69 Hard top
srode is offline
post #2 of 11 (permalink) Old Nov 22nd, 19, 04:25 AM
Greg
pittpens24's Avatar
Re: spot weld bit choice
I think I did Harbor Freight for like $5 each and buy like 4 or 5. Don't waste your money on a $30 bit - they break too fast to be worth it
350sshugger likes this.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 11 (permalink) Old Nov 22nd, 19, 04:46 AM Thread Starter
what size? 3/8, 5/16, ....
srode is offline
post #4 of 11 (permalink) Old Nov 22nd, 19, 05:12 AM
Matt
X2 Harbor Freight. I did my entire car with 2 bits, which was a lot of metal if you have seen my build. Keep the rpm low and use WD-40 for cooling and they will last for a lot of cuts.
yellow69RS likes this.
My Build Thread
350sshugger is offline
post #5 of 11 (permalink) Old Nov 22nd, 19, 05:16 AM
I grind them down with a cutoff wheel or air file and then hit them with a spot weld buster. Life is too short to drill out spot welds.
Luwi67 likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 11 (permalink) Old Nov 22nd, 19, 05:40 AM
Greg
pittpens24's Avatar
Now that I have 4 years under my belt cutting and grinding I can see that as a timesaver, BUT in the beginning when I never picked up a cut-off wheel, I could just imagine the quick damage I could have done to that inner rocker LOL.
Seriously though - I did cut my floor out with a plasma cutter 1st so I could work like a human instead of having the drill chuck rub on the floor when drilling out. Just be mindful of your cuts!
Moser 9" with 4:11
572 BB - CM Engines
post #7 of 11 (permalink) Old Nov 22nd, 19, 07:02 AM
keith
X-77 keith's Avatar
I agree with Don. I use to drill out the welds, but grinding is faster, and leaves a area with no holes for you to weld to. No brainier to me.
X-77 keith
X-77 keith is offline
post #8 of 11 (permalink) Old Nov 22nd, 19, 07:09 AM
Darin
ilikeike's Avatar
I use Blair when needed. Good brick and mortar local welding stores carry them
or Amazon. You can find lesser bits that do the job though.
https://www.blairequipment.com/spotweld-cutters
When I just did my mini tub job, I mostly just used a drill bit, grinder, chisel and hammer.
It's nice to have a good spot cutter if needed though.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 11 (permalink) Old Nov 22nd, 19, 08:21 AM
Darrell
I used the HF spot weld cutters after using a plasma cutter to get rid of the mass of the floor. Then I ground off the nugget that was left until it was smooth with the surface. The trick is to just cut thru enough to release the floor metal and not to go though the base metal. Patience is your friend.
My build thread
Checkered Past is offline
post #10 of 11 (permalink) Old Nov 22nd, 19, 08:26 AM
I bought a cheap set of spot weld bits from Amazon. For sheet metal they would work OK but the thick metal of my shifter detent they died quickly killing 1 bit per spot weld. I also have used the HF ones which are about the same quality. Both work OK on sheet metal but thicker stuff....they are short lived.
The surrounding metal is no problem...the weld itself is considerably harder
Like any tool, quality has a price so you typically get what you pay for. YMMV
SoCal805 is offline
post #11 of 11 (permalink) Old Nov 25th, 19, 04:39 AM
Greg
pittpens24's Avatar
You know what they say - Bigger is always better lol
Moser 9" with 4:11
572 BB - CM Engines
