To Cover or Not to Cover ... - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 15 (permalink) Old Jan 17th, 20, 05:30 PM Thread Starter
Bob
I will (eventually??) be getting my 68 back from the body shop with new paint. Car will be garaged, but my garage is detached with open gables/framing, etc. Here in the Los Angeles area, things in my garage quickly get covered in a coat of nasty/abrasive dust. So I am looking for advice on whether to use a car cover or not. I am thinking of an indoor cover that has a very soft lining material, but ideally would provide a little protection from minor bumps or scrapes. Any thoughts as to yes or no? Any suggestions for type/brand of cover?
bobgonefishin is offline
post #2 of 15 (permalink) Old Jan 17th, 20, 06:04 PM
Bill
bill3337's Avatar
Re: To Cover or Not to Cover ...
Yes, I'd recommend using a soft cotton lined cover. I have several different covers, but the car wants to be spotlessly clean when you put it on, best to use two people, so you don't have to drag it along the surface. It won't protect against hard knocks, but will keep the abrasive dust off it. Depending on how much of that dust that you get, you may need to take the cover to a laundromat every so often to keep it clean. I've got several different brands, but I like the California Car Cover soft cotton cover, good for only interior use.https://www.calcarcover.com/product/...car-cover/3930.
bill3337 is online now
post #3 of 15 (permalink) Old Jan 17th, 20, 06:22 PM
DjD
DjD's Avatar
Talk to your painter. At some point you will want to cover the car but like waxing it may take a while before you want to mess with the paint surface.
...Dennis
DjD is offline
post #4 of 15 (permalink) Old Jan 17th, 20, 06:50 PM
Vega$69's Avatar
I keep my Classics and my Vettes covered.
Calif Car Dustop on my classics and nylon stretch covers on my Vettes.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 15 (permalink) Old Jan 17th, 20, 08:03 PM
I use a Budge brand cover when needed as a dust cover in my shop.
my 67' build thread:
allanjs is offline
post #6 of 15 (permalink) Old Jan 17th, 20, 09:48 PM
Rene
rsbecool's Avatar
Mines always covered in the garage. Buy the best you can afford as soon as the painter give you the green light to cover it. Billís advice on having the car clean before covering it is spot on and using two people so you donít drag it makes perfect sense to me
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
TC #24
rsbecool is offline
post #7 of 15 (permalink) Old Jan 18th, 20, 07:12 AM
Wiley E. Coyote
IE area moved from LA
Bought a $40 indoor cover off ebay yrs ago love it. Lined, lightweight isnt too tight where it wears on corners.
cv67 is offline
post #8 of 15 (permalink) Old Jan 18th, 20, 09:12 AM
scblucam's Avatar
I waited until I didn't smell the paint off gassing before I washed it and covered it. But even some of the best covers fine dust will eventually sift through. I usually don't have an assistant so I roll the cover and unroll it on the car so it doesn't drag.
68 302 M20 - 85 IROC Z
scblucam is offline
post #9 of 15 (permalink) Old Jan 18th, 20, 09:29 AM
kevin
my wife sewed 3 quality bed sheets together. that way I can fold each side to the center, then roll the sheets for removal
then just replace and unroll. no dragging no scratching
I heat with coal. it is dirty when removing ashes ,but the sheets keep the car clean
flat tire is offline
post #10 of 15 (permalink) Old Jan 18th, 20, 11:18 AM
Brandon
As mentioned above, check with the painter. Some may stress giving the paint a rest period before anything goes on it. I think I was told 1 month before wax or covering. Then a rinse with good water, blow dry with leaf blower or shami. Nice coat or two of wax, light buffing then cover. But all depends on the paint used.
Brandon J. licence 1NASTY67
Nantooch is online now
post #11 of 15 (permalink) Old Jan 18th, 20, 11:45 AM
for indoors the flanel ones are great and you can throw the in the wash
I have had one of their Noah covers for 20+ years now. Outdoor rated but works well inside
Use a duster first before putting cover on.
Let the new paint job "cure" for at least a month before doing anything
SoCal805 is offline
post #12 of 15 (permalink) Old Jan 18th, 20, 07:17 PM Thread Starter
Bob
Thanks for the replies. I know that I will need to let the paint cure for a while. I'm looking more at the long term picture. Leaning toward a cover like the Dustop that will give a bit of added protection in case "someone" carrying something past my car accidentally makes contact.
I will go with either House of Kolor or Axalta Cromez, depending on my final color choice. I've heard from some folks that you can only use waterborn paint in SoCal, but that's not the case. Both companies make good clears in urethane that are VOC compliant and supposedly cure to a very hard finish.
post #13 of 15 (permalink) Old Jan 19th, 20, 05:37 AM
bob
I have a duststop cover on my car. It was replacing a 28 year old cover. I have no complaints with it.
When my car was painted back in 1992 (glasurit urethane paint), I let the car sit uncovered in the garage for about 10-12 weeks before I did anything to the car.
bob15 is offline
post #14 of 15 (permalink) Old Jan 23rd, 20, 09:29 AM
Apprentice
Charlie
Is going after the root cause out of the question? Are you able to completely enclose the garage and prevent the nastiness in the first place? If possible recommend that, followed up by installing a ductless A/C to control the environment. Your car will love it. Just a suggestion
sschas is offline
post #15 of 15 (permalink) Old Feb 10th, 20, 04:42 PM Thread Starter
Bob
Would be very difficult/expensive to enclose the garage. Its large with open gables, framing, etc. Also I spend a lot of time there and the 18 ft wide door, which I leave open during the day is the only entrance. Thanks.
