Powder coating and colors - Team Camaro Tech
Body Shop Paint & Body Forum
 1Likes
  • 1 Post By flat tire
post #1 of 9 (permalink) Old Jan 24th, 20, 05:21 AM Thread Starter
Apprentice
Morning all
Looking for a recommendation
Someone youíve used and referred to others for powder coating in north or central New Jersey.
Has anyone had powder coat colors matched to vehicle paint codes? Iíve seen color options but hoping for an exact match.
CM68MM is offline
post #2 of 9 (permalink) Old Jan 24th, 20, 09:03 AM
Robert
Re: Powder coating and colors
What are you looking to powder coat? Are you looking to do smaller pieces and parts or large parts like the subframe?
Powder coating to a vehicle paint code might prove to extremely challenging. I would think they should be able to get really close though.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #3 of 9 (permalink) Old Jan 24th, 20, 09:59 AM
Roger
rogerh's Avatar
I have had nothing but trouble with powder coating where bolting it is required. If anything breaks the surface of the powder coating and allows moisture to get next to the metal youíre in trouble.
Roger
rogerh is offline
post #4 of 9 (permalink) Old Jan 24th, 20, 10:12 AM Thread Starter
Apprentice
Wheel well and rocker trim - maybe a few other things but definitely not going to go too crazy with the crocus yellow
CM68MM is offline
post #5 of 9 (permalink) Old Jan 24th, 20, 10:15 AM Thread Starter
Apprentice
Roger
Good point and thanks! I didnít think of that. Wheel well trim might not be the best candidate then.
CM68MM is offline
post #6 of 9 (permalink) Old Jan 24th, 20, 10:34 AM
kevin
check out cerakote
I had intake, thermostat housing, alternator, timing cover and bolt heads coated. then I did the water pump myself. all require bolts and I have had no problem with cracking or pealing
ME4NSTRK69 likes this.
flat tire is offline
post #7 of 9 (permalink) Old Jan 24th, 20, 11:07 AM Thread Starter
Apprentice
Originally Posted by flat tire View Post
check out cerakote
That picture reminds me of my Cindy Crawford poster. Thing of beauty
CM68MM is offline
post #8 of 9 (permalink) Old Jan 24th, 20, 04:22 PM
I worked for a powder coating Mfg. for almost 10 years. You CAN color match, but it "could be" costly, it's not anything like liquid paint other than the name.
Some of our testing was really impressive for taking abuse.
Good luck in your quest
68 Camaro~LSx ~all motor
post #9 of 9 (permalink) Old Jan 24th, 20, 07:53 PM Thread Starter
Apprentice
Thanks - on another thread I was looking for "paintable" trim (without chrome). Still looking for that as option 1 but option 2 would be stripping the chrome and powder coating to match paint. Option 3 is "chrome only" trim. Would love the ability to switch between chrome and matching painted/powder coated molding/trim...
CM68MM is offline
