Caltracs with multi leaf springs?? - Team Camaro Tech
Performance Our High Performance area
 2Likes
post #1 of 18 (permalink) Old Jul 14th, 08, 09:55 PM Thread Starter
So it sounds like the split mono spring is the ultimate set up to use with Cal Tracs. I'm just wondering how many of you folks are using them with multi leafs and how they are working out? What is the real advantage of mono vs multi leafs? Anyone do a direct comparison of the two setups?
68 Camaro, 355, Forged pistons, rods and crank, Edelbrock Alum Heads, Air Gap w/Street Avenger, CC 280H, MSD Dist & Digital Box, T400 w/brake & 4200 stall, 513 gears, 11.66 @ 120 (with 150 shot) Street driven (occasional strip use)
sneakey pete is offline
post #2 of 18 (permalink) Old Jul 15th, 08, 06:05 AM
Greg
Re: Caltracs with multi leaf springs??
I ran both and ended up with the stock multi leafs. The split mono's are very thick and stiff. If you have a ton of power they do a better job of controlling the chassis separation. At my lower power lever I wasn't getting enough chassis separation even with the softest shock and bar settings so I switched back to the multi's.
The split mono's are a great set up for sure, but not a "must have" IMHO.
Larger Dave likes this.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, street car, Water/Meth injection
1.302 60', 5.956 @ 116.4 Super Sniper EFI 2019
Greg O is offline
post #3 of 18 (permalink) Old Jul 15th, 08, 08:09 AM
Eric
I wound up with Greg's old split monos. But I run Slide-a-links (very similar to Cal tracs).
I ran both the split monos and multi-leafs with the S-A-Ls and honestly, it didn't make a hill 'o beans.
Eric68 is offline
post #4 of 18 (permalink) Old Jul 15th, 08, 08:35 AM Thread Starter
Thanks for the comments. Makes me more comfortable with decideing to go with them (I think I will be ordering a set soon). As You guys both have have a ton of torque more then I do mine should work just fine without any issues. Thanks gentlemen. I'm having trouble trying to figure out why I can't get a better 60' then 1.7 car seems to hook okay as it pulls the front wheels a good 6" (but then drops quick, not sure if brakes loose but keeps straight) pulls like an animal from launch to 7000. Hoping the Cal Tracks will give me something. Car runs 11.6 at 120 so my 60' should (in my opinion) be in the 1.55 to1.65 range. Go figure.
Cheers
post #5 of 18 (permalink) Old Jul 15th, 08, 09:28 AM
Kevin
1.7 without Cal Tracs? You must have something else on there now with your multileafs? I fabbed an adjustable pinion snubber to do me while I save up for bars. Works pretty good though so I might just keep it this way.
Autosmiths, LLC
'69 X44, stock 350 (for now), TH350, 3.70:1 gear 8.5" 10 bolt, Auburn Posi.
speedshifter is offline
post #6 of 18 (permalink) Old Jul 15th, 08, 11:16 AM Thread Starter
Not too sure how I ended up with the double post but this should take care if it. Yes I'm running slapper bars (Comp Engineering) now and set pretty much up tight, can maybe slide a piece of paper between the snub and the spring so not much travel left. And I forgot to mention the 11.6 is with a 150 shot of juice as the car by itself only runs 12.5 at 109.
Cheers
post #7 of 18 (permalink) Old Jul 15th, 08, 12:16 PM
I ran stock multileafs with my old motor (454) with just the Cal Tracs and had a consistent 1.59/1.60 60ft with a 11.60 ET
1969 Camaro, 548ci, 10.6:1, solid roller, Ford AOD, 4000 Stall, 12 bolt with 4.11's
New best, 10.59 at 125.48, 1.39 60ft
Cali Z28 is offline
post #8 of 18 (permalink) Old Jul 15th, 08, 03:41 PM
Trevor
I run Caltracs on a multi leaf set up and love them. I lanch at 5200RPM on the two step with very little wheel spin. That is with a 4spd MT.
osin68 is offline
post #9 of 18 (permalink) Old Jul 15th, 08, 05:30 PM
1.7's w/ slappers...
Homemade Caltrac copies...1.64's now
I'm running 4 leaf JCWhitney replacements,3.73's,MT DR's
68 Camaro~LSx ~all motor
post #10 of 18 (permalink) Old Jul 15th, 08, 08:37 PM
Greg
sneaky, you may want to just try adding some Rancho's to your current set up first and see what they gets you. I actually loved my slapper bar set up but it got to where it didn't hook consistantly. Thing is I had stock gas shocks on the back and never tried adjustables. The slappers produce a really hard hit and an IC way to the back. If you put some Rancho's on there and set them to stiff it might work out. You can always add the Cal Tracs later if that doesn't work but you will have to have the Rancho's with them any way.
Just a thought....
Greg O is offline
post #11 of 18 (permalink) Old Jul 16th, 08, 07:39 AM
2x2' square tube slapper bars welded to the stock spring pads,
snubbers cut about 1/2" off the top.
Stock springs and worn Sears HD shocks.
Results are below.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #12 of 18 (permalink) Old May 29th, 19, 09:20 PM
Bill
I have the caltracs on my 68. multi leaf with sub frame connectors and solid frame bushings. I have calracs 90/10s and adjustable shocks on rear. my best 60 ft is 1.5980, best 1/8 is 7.5689. I have the rear shocks set on 9
Long Island Mouse is offline
post #13 of 18 (permalink) Old May 29th, 19, 09:38 PM
scblucam's Avatar
Wow, is someone keeping track of length of time for reviving old posts?
68 302 M20 - 85 IROC Z
scblucam is offline
post #14 of 18 (permalink) Old Jun 1st, 19, 08:19 PM
Not Camaro(Nova), but my split mono's hook up way better than my multi's used to
rodent4 is offline
post #15 of 18 (permalink) Old Jun 10th, 19, 04:56 PM
Greg
Well, since someone dug up the old thread, I'll update. lol. A few years later I added a ProCharger which upped the power considerably. The factory multi's could no longer control the chassis so I went back to split mono's. They work well but the key to the whole thing is a good set of double adjustable shocks. I put that off forever trying to save money but should have done it up front.
Greg O is offline
