Eagle Field 2018 - Team Camaro Tech
Performance Our High Performance area
 5Likes
  • 5 Post By Steve69SS396
post #1 of 3 (permalink) Old Oct 8th, 18, 10:23 PM Thread Starter
Steve69SS396's Avatar
Eagle Field 2018
Took my car to Eagle Field in Firebaugh, California on Sunday. Been there many times. Some good 1/8 mile drag racing, run what you brung type stuff. The track is an old air field and the races are 1/8 mile. I only made 2 passes because I blew a header gasket. On the first pass I left in 2nd gear at 50% throttle and went full throttle for just the last second. It ran 6.857 at 108MPH. On the second pass I also left in 2nd gear at 50% throttle and after about 2 seconds, went full throttle. It ran 6.63 at 113mph. After the first pass I noticed a small exhaust leak. After the 2nd pass the exhaust leak was huge! It blew out a chunk of the gasket. The track was hooking and I was ready to try launching in 1st gear, but I was not going to run my car with a huge exhaust leak. Here's the video.
Steve69SS396 is offline
post #2 of 3 (permalink) Old Oct 9th, 18, 08:22 AM
Darin
ilikeike's Avatar
Re: Eagle Field 2018
Dang, I didn't catch your car run.
My buddy made a couple passes Sunday morning in his white 73 Camaro, I forgot the time but he ran 98 mph ,with his new 406 and a loaner 650 Holley, then we loaded up.
Saturday we had 3 cars and 2 mini bikes to run, it was fun but the wind sucked big time.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 3 (permalink) Old Oct 14th, 18, 10:07 AM
Apprentice
Very nice!! Can’t wait to see the 1st gear launch.
68 SS, MJ 467, 200-4r, 3.73 12 bolt
Pize is offline
