Anyone do a 400 based 302? - Team Camaro Tech
Performance Our High Performance area
 6Likes
  • 1 Post By Larger Dave
  • 2 Post By bhodgdon400
  • 1 Post By ilikeike
post #1 of 15 (permalink) Old Sep 24th, 19, 01:26 PM Thread Starter
Wiley E. Coyote
With the lack of tq and guys worrying about hurting their 302 why not take a 400 block, run your 3.5 stroke solid xxx cam and slap a 302 aur cleaner on it?
Anyone thats had one of these knows how brutal the torque can be on them too much fun.
Curious, somoene here has done it?
cv67 is offline
post #2 of 15 (permalink) Old Sep 24th, 19, 01:39 PM
Lorne
Re: Anyone do a 400 based 302?
I built a 400 but not to 302 specs it was a 406 & was it a torque monster. I puit it in a 82 Vette & it was a blast to drive, approx 400 hp & 500 ft/lb torque. Sold car sans engine & now my son wants to put it in his truck.
hiperf406 is offline
post #3 of 15 (permalink) Old Sep 24th, 19, 03:00 PM
I would buy a BluePrint 400. Fresh block stronger than the stock block by far.
https://blueprintengines.com/product...etor-bp4002ct1
Drop on manifold, install distributor and add your old air cleaner and enjoy the drive.
You can store the original DZ 302 for posterity, in the same crate that your 400 arrived in.
Big Dave
Z282NV likes this.
Larger Dave is offline
post #4 of 15 (permalink) Old Sep 25th, 19, 07:48 AM
Ben
been doing the 400, 421, 434, 406 thing for 20 years. never considered de-stroking though. i dont need to spin 7,000 RPM, just pull stumps and front wheels
kookykrispy and spoffie1962 like this.
bhodgdon400 is offline
post #5 of 15 (permalink) Old Sep 25th, 19, 08:05 AM
Darin
ilikeike's Avatar
Pulling 2nd gear from almost a stop at the auto-x is nice,then going to 6,500rpm. I should have went solid lifters for another 500rpm or so.
bhodgdon400 likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #6 of 15 (permalink) Old Sep 25th, 19, 08:27 AM
Ben
exactly, why de-stroke and take away the advantage of a big cube small block? with todays cam profiles and parts, the right 421 / 434 can spin to 7,000 safely and still pin you in the seat at 2,500.
just dont see the fun in spinning a little motor to 8,500 anymore. especially not where i drive 95% on the street....i'd never see the benefit
post #7 of 15 (permalink) Old Sep 25th, 19, 09:16 AM
A 302 was built as a 302 because it was competing in the five liter motor size, against European five liter sedans, That is why the 302 exists, it was a sports car ready to race; beating up on Jaguars and the occasional Mustang with their 302, until American Motors handed them their heads for three years in a row thanks to Donohue. After that Ford's Roush Racing dynasty won the next six season in a row which is why Chevy stop sponsoring the race.
If you wanted to go TransAm racing in the seven liter class you raced a 'Vette: but you were competing against Ferrari, a whale tail Turbo Porsche six bangers and again Jag this time powered by with a V12 instead of an in-line six cylinder. Not to mention Lamborghini, Maserati, Audi and BMW all running V12 turbo powered cars. Wasn't much fun for the 'vette teams.
They claimed it was a driver's race but the cars seamed to matter more than the driver ever did at least from a spectator's point of view.
Big Dave
post #8 of 15 (permalink) Old Oct 17th, 19, 01:13 PM Thread Starter
Wiley E. Coyote
Wouldnt destroke one personally but some are stuck on the rev quick thing (whatever)
are the BP blocks as hard as a Dart or GM?
cv67 is offline
post #9 of 15 (permalink) Old Oct 17th, 19, 04:23 PM
Vega$69's Avatar
My 1st I wouldn’t worry about hurting my 302. If I was 2nd choice would be 406 SBC badged as 302 next would be 302 badged 383.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 15 (permalink) Old Oct 17th, 19, 06:19 PM
Joe
Big Dave
I like this approach, but would the finned aluminum 302 valve covers fit as well? I have no clue if there would be any valve train interference.
Z282NV
1969 Camaro
Z282NV is offline
post #11 of 15 (permalink) Old Oct 17th, 19, 06:22 PM
Jeff
yellow69RS's Avatar
I'm from the " there's no substitute for cubic inches" school so destroking a 400 makes no sense to me. That said whatever size motor ends up in my car it will be "dressed" as a 302.
Jeff
yellow69RS is offline
post #12 of 15 (permalink) Old Oct 17th, 19, 07:31 PM
They did on my 406 with BBC PAC valve springs 1.6:1 roller rockers (chrome-moly body, not the fatter aluminum body), and 3/8th inch diameter push rods. Shame Photo For Money screwed every one or I could show pics.
Will admit took grinding oil drippers and thick Moroso permanent steel core silicone rubber valve cover gaskets to clear.
Big Dave
Z282NV likes this.
post #13 of 15 (permalink) Old Oct 17th, 19, 07:38 PM
Steve69SS396's Avatar
Not sure why people think a stroker won't RPM. My 4" stroke 427SBC has no problem bouncing off the 8,000 rpm limiter. On this pass it does it while in the burnout as I shift from 2nd to 3rd. The shift light was set at 7,200 but the shifts didn't happen until about 7,500.
Steve69SS396 is offline
post #14 of 15 (permalink) Old Oct 18th, 19, 09:04 AM
Probationer
You can run a de-stroked 400 by using a 350 crank.You get a 377 cubic inches.with an engine that likes to rev upstairs. But it depends on what the car is built for And the rules as well. I have my friend and build an supercharged engine for my 1979 Z-28 ProTouring car. It has a Chevrolet "bowtie block" bored .040 over with a Scat stroker forged crankshaft .with all the "toys" I can rev it up to 6500 rpm. It makes around 500 HP with 15lbs of boost .
Michael Watts is offline
post #15 of 15 (permalink) Old Oct 18th, 19, 11:47 AM
NHRA's new 840 cubic inch Mountain Motor Pro Stock class shifts at 8,400 due to the size (weight) of the pistons and the length of the stroke. Sonny Leonard's 903 IHRA Mountain motor with five stages of nitrous to helkp prevent blowing off the tires revs the same. So if you want to wind it up a long stroke will twist as high as a SBC it just is going to cost you more in replacement costs.
The Sonny 903 lists for $104,000 complete. Which is a lot more than the $35 bucks I used to pay every week for a Power Pack 283 out of the junk yard to replace the one that launched the rods through the block in my '55 Chevy when I used to twist them to ten grand.
All depends upon how you want to drive it and how deep your pockets are (It also helps to own your own wrecker and a garage with all of the equipment to work on a car like I did back in the seventies).
Big Dave
yellow69RS likes this.
