582 BBC pump gas. HP / Torque estimate - Team Camaro Tech
Performance Our High Performance area
post #1 of 3 (permalink) Old Jan 24th, 20, 03:28 PM Thread Starter
Probationer
Dan
So Iím having a 4.6 bore/. 4.375 stroke built
Merlin block 10.1 compression
Brodix BB2 extra head 2.30 intake 1.88 exhaust valve. 365cc intake runner.
Solid roller cam .731 intake .737 exhaust lift
.273 IN ..277 ex @.050. 106 intake c/l on a 110 lobe sep.
Intake is a single plane team G
Carb is quick fuel 1050 on a 4150 base.
Jesel belt drive/ msd cranktrigger
Question what kind of HP and Torque numbers
What size header .
1968 camaro strip some limited street.
3500 race weight.
Thank you
dweyrauch is offline
post #2 of 3 (permalink) Old Jan 24th, 20, 04:19 PM
Darin
ilikeike's Avatar
Re: 582 BBC pump gas. HP / Torque estimate
How'd your 489" do ?
Have you tried the $50 desk top dyno ?
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 3 (permalink) Old Jan 25th, 20, 07:11 PM
R/T
Jack
750 hp 730 tq.
Dan with the BB2-x heads. The exhaust ports are raised .600 over stock. Might need a custom header to fit. Give Lemons header a call. Give them the specs. of your car and engine. They can help you. Be warned they are not cheap. But worth it.
Matthew 22: 37-39
R/T is offline
