69 Camaro RS Build Project - Team Camaro Tech
Build Projects follow along start to finish
post #1 of 36 (permalink) Old Jun 6th, 13, 09:40 PM Thread Starter
tim
Hi I am restoring a 69 camaro rs So I will be positing the build on it. I plan on using a ls1 motor from a 1998 camaro ls1 here is what I will be building from. Looks kinda rough but I have a vision for it. I was thinking of protouring it unless you guys think I should do something different.
This is the donor a 1998 camarao z28
rimspec is offline
post #2 of 36 (permalink) Old Jun 6th, 13, 09:57 PM
Vintage 68's Avatar
Re: 69 Camaro RS Build Project
Duplicate post - https://www.camaros.net/forums/showthread.php?t=219838
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 36 (permalink) Old Jun 6th, 13, 10:35 PM Thread Starter
tim
What parts can I use off the donor car? I heard you can use the brakes off the car also so the 69 can use disc brakes? Any recommendatiosn on how to do the engine swap?
rimspec is offline
post #4 of 36 (permalink) Old Jun 7th, 13, 05:29 AM
Todd
6781camaro's Avatar
Looks like you have cleaner car to start with. RS too! If it were me, I'd keep it bone stock-looking on the outside, since it's an original RS, and then update everything else internally and drive-train-wise. An RS Stealth-Sleeper! Have fun and welcome aboard!
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too),
'67 White 6 Cyl Coupe Building now (three!)
'68 Conv. V8 4-spd Builder, '68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
My build thread:
6781camaro is offline
post #5 of 36 (permalink) Old Jun 7th, 13, 09:55 AM Thread Starter
tim
Did I make a okay choice the engine?
rimspec is offline
post #6 of 36 (permalink) Old Jun 7th, 13, 07:12 PM Thread Starter
tim
Here some more updates took the fender off fixing imperfections on the body and customizing it
Taking dfenders off and fixing imperfection and getting ready to powder coat the sub frame
rimspec is offline
post #7 of 36 (permalink) Old Jun 7th, 13, 07:29 PM
Todd
6781camaro's Avatar
Definitely.... You may want to visit some of the most recent threads where they are making this conversion too. LOTS of good info packed into their threads if you need assistance and tips.
https://www.camaros.net/forums/showthread.php?t=208788
https://www.camaros.net/forums/showthread.php?t=215575
My build thread:
post #8 of 36 (permalink) Old Jun 12th, 13, 12:02 AM Thread Starter
tim
making custom side vents for the camaro please stay tuned...
RIMSPEC WHEEL REPAIR
AND
1-888-789-9951
Allstar Auto Salon Body Paint Collision & Classic Restoration & Protouring
1-888-344-3417
rimspec is offline
post #9 of 36 (permalink) Old Jun 12th, 13, 12:04 AM Thread Starter
tim
Any recommendation for oil pans for a ls1 conversion? Supension wise what would you guys use?
AND
1-888-789-9951
1-888-344-3417
rimspec is offline
post #10 of 36 (permalink) Old Jun 12th, 13, 04:12 PM
Vintage 68's Avatar
Thumbs up Re: 69 Camaro RS Build Project
Oil pan, I've used a modified 'Hummer' pan, the GM Performance kit, and the Holley system.
All have fit fairly well, but the Hummer took some mods ...
GM kit - http://www.summitracing.com/parts/nal-19212593
Holley kit - http://www.summitracing.com/parts/hly-302-1
For suspension, other than mod stock I've been very happy with both Hotchkis and DSE parts.
Pricier, but worth it ...
1968 Convertible
Some trucks
post #11 of 36 (permalink) Old Jun 12th, 13, 05:10 PM Thread Starter
tim
how much mods did u have to do on the HUMMER pan
AND
1-888-789-9951
1-888-344-3417
rimspec is offline
post #12 of 36 (permalink) Old Jun 12th, 13, 05:13 PM Thread Starter
tim
Also I was thinking of usingthe factory disc brake conversion I heard you can order the parts from gm? Does any one have a parts list of what i need to get this done
AND
1-888-789-9951
1-888-344-3417
rimspec is offline
post #13 of 36 (permalink) Old Jun 12th, 13, 10:59 PM
Vintage 68's Avatar
Wink Re: 69 Camaro RS Build Project
The Hummer pan needs to be checked carefully for cross link clearance.
The choice/type of mount(s) you have or select will dictate what work needs to be done to get there.
Brakes are a huge personal choice area.
Some are just looking for better cruise type systems while others are driven to put the biggest system on thy can - whether thy need or can use it at all ...
Here's a link to Dave's excellent ite ith lots of options for upgrades - http://www.pozziracing.com/12_corvet...es_on_fgen.htm
1968 Convertible
Some trucks
post #14 of 36 (permalink) Old Jun 13th, 13, 11:20 AM
jno
Nice project you have there. Looks like a better starting point than most projects posted here.
I do have one question; What is that huge engine lathe doing in an auto shop?
jno is offline
post #15 of 36 (permalink) Old Jun 14th, 13, 08:49 AM Thread Starter
tim
we do metal fabrication and wheel repair service as well as auto body and car customization
AND
1-888-789-9951
1-888-344-3417
rimspec is offline
