1969 Plain Jane Build in Michigan - Page 5 - Team Camaro Tech
Build Projects follow along start to finish
 9Likes
post #61 of 68 (permalink) Old Aug 7th, 19, 08:29 AM Thread Starter
DaveS44's Avatar
Re: 1969 Plain Jane Build in Michigan
Update to the trunk pan prep. This has been a bugger to get into the tight areas.
1969 Plain Jane Coupe
DaveS44 is offline
post #62 of 68 (permalink) Old Aug 7th, 19, 08:44 AM
Tim
Yikes! Hidden surprises are so much fun...
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #63 of 68 (permalink) Old Aug 16th, 19, 04:50 PM Thread Starter
DaveS44's Avatar
Just about ready for the trunk pan fit up. I thought I'd leave the weatherstrip channel in for strength until the floor is welded.
DaveS44 is offline
post #64 of 68 (permalink) Old Oct 2nd, 19, 08:59 AM Thread Starter
DaveS44's Avatar
My project has been on pause while I shop for a new air compressor. Mine finally gave out.
DaveS44 is offline
post #65 of 68 (permalink) Old Oct 18th, 19, 09:51 AM Thread Starter
DaveS44's Avatar
Do I have to remove the decklid hinge support bracket to fit the full pan in? It doesn't seem to fit.
DaveS44 is offline
post #66 of 68 (permalink) Old Oct 18th, 19, 10:59 AM
Dave, I had the brackets removed from the inner wheel houses when I replaced the
full trunk on my 67. If I remember correctly it was needed to fit the full trunk.
DaveS44 likes this.
my 67' build thread:
allanjs is offline
post #67 of 68 (permalink) Old Oct 29th, 19, 01:48 PM
Rich
Man nice get r dun attitude! I'm so glad I no longer live up north, while our floors and trunks still rust from leaks at least they don't get this bad from salt
A while back you mentioned doing up the rear end, may I suggest to look for a Nova 8.5 and upgrade in strength and parts availability and most Nova's 72-78 are multileaf perches you will need to shorten driveshaft about 2" but these are almost as strong as a 12 bolt
carry on sir
DaveS44 likes this.
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #68 of 68 (permalink) Old Nov 7th, 19, 08:26 AM Thread Starter
DaveS44's Avatar
carry on sir
Thanks for the idea. That may be a future upgrade. At this point I just want to get it on the road.
DaveS44 is offline
