69 rustbucket rebirth - Page 73 - Team Camaro Tech
Build Projects follow along start to finish
 284Likes
post #1081 of 1096 (permalink) Old Nov 16th, 19, 07:37 PM
Randy
Re: 69 rustbucket rebirth
Looking good Matt!
350sshugger likes this.
My 69 Camaro build thread:
rsgt is offline
post #1082 of 1096 (permalink) Old Nov 19th, 19, 06:53 AM
DaveS44's Avatar
Originally Posted by 350sshugger View Post
Finally an update.
I also found a broken lever in the controls which I need to replace. Thankfully that's a common problem and parts are on the way.
Careful not to break the tab that holds the front plate on. Also the levers without the knobs are sharp. Don't ask me how I know these two things. - Dave
1969 Plain Jane Coupe
DaveS44 is offline
post #1083 of 1096 (permalink) Old Nov 20th, 19, 06:41 PM Thread Starter
Matt
Thanks for the tip Dave. The kit just showed up (old air parts) so maybe this weekend I'll attempt it.
I just happened to see your comment on the extra fender I have. Let me know if you would like to see it.
DaveS44 likes this.
My Build Thread
350sshugger is offline
post #1084 of 1096 (permalink) Old Nov 23rd, 19, 07:07 PM Thread Starter
Matt
I've completed the lever replacement. Not much to it, other than like Dave mentioned be careful not to break the tabs. They're pot metal and fragile, and even being careful I did partially break one. Also in my research guys have been grinding off the rivets and that isn't necessary. Just break off the spring washers and they'll drop out. After that it's just R&R. I used the opportunity to clean up the slides and the linkage and also lube everything up good.
I spent the rest of the day wiring which doesn't look much different when you're done but takes forever. But every connector finished and plugged in is one step closer.
ID:	230937   Click image for larger version
ID:	230939   Click image for larger version
ID:	230943   Click image for larger version
ID:	230945   Click image for larger version
allanjs likes this.
My Build Thread
post #1085 of 1096 (permalink) Old Nov 25th, 19, 08:07 AM
Ed
Absolutely beautiful! good luck
ZEN357 is offline
post #1086 of 1096 (permalink) Old Dec 2nd, 19, 07:51 PM Thread Starter
Matt
Transmission time! Merry Christmas to myself. SST has been working with me for the past year on my kit and I pulled the trigger 2 weeks ago.
Dropped the engine off the stand and used some emery to clean up the pilot bearing bore. Then installed the bearing; o-ring side goes toward the transmission.
My clutch kit is an LS6 kit from Rock Auto. Includes everything but the flywheel bolts, which I got from Summit Racing in another order months ago. Installed the flywheel and bellhousing and then swept the rim and face. I had .005 TIR on the rim and .002 on the face; both within spec.
Cleaned all the oil off the flywheel and pressure plate. Installed and torqued to 52 ft-lbs. Installed my throw out bearing (slave cylinder since it's hydraulic) and measured the clearance. Without shims it's on the tight side so I'll let it ride. Slave cylinder is a 2002 Camaro part also from Rock Auto.
Lifted the trans and slid into place (ate my Wheaties this morning) and torqued trans down to 35 ft-lbs.
I've got a little work to do on the firewall and then I'll wrestle this into place tomorrow!
ID:	231145   Click image for larger version
ID:	231147   Click image for larger version
ID:	231151   Click image for larger version
ID:	231153   Click image for larger version
ID:	231157   Click image for larger version
My Build Thread
post #1087 of 1096 (permalink) Old Dec 2nd, 19, 08:10 PM
And the excitement grows !! Nice work Matt.
my 67' build thread:
allanjs is online now
post #1088 of 1096 (permalink) Old Dec 3rd, 19, 06:08 PM Thread Starter
Matt
Yes it does! Thanks Al.
allanjs likes this.
My Build Thread
post #1089 of 1096 (permalink) Old Dec 3rd, 19, 06:20 PM Thread Starter
Matt
I did it. She's shoehorned in there. My lady gave me an extra set of hands and apparently was snapping pictures. For those interested, this is what an LS with a T56 and the complete Holley install kit looks like. Lots of room with no tunnel mods.
Everything that could fight me did. Could not get it in with any front metal on due to picker reach. Had to remove shifter and both headers. Had to modify the spreader bar mid lift because the crank was contacting picker. But she's in and secure and no damage was done; thank the Lord.
I did mock the shifter location using the center console. Cut an initial square too small and then whittled the opening just large enough to get the shifter through.
ID:	231161   Click image for larger version
ID:	231163   Click image for larger version
ID:	231167   Click image for larger version
ID:	231169   Click image for larger version
ID:	231173   Click image for larger version
HawkX66, dhutton, allanjs and 4 others like this.
My Build Thread
post #1090 of 1096 (permalink) Old Dec 4th, 19, 07:08 AM
^^^wish this was mine :-)
If it isn't on the list....consider sub frame connectors.
SoCal805 is offline
post #1091 of 1096 (permalink) Old Dec 5th, 19, 04:16 AM
Charlie
Congrats! Looks great!!!
My '67 basketcase:
vetteman_72 is offline
post #1092 of 1096 (permalink) Old Dec 5th, 19, 08:04 PM Thread Starter
Matt
Originally Posted by SoCal805 View Post
^^^wish this was mine 🙂
Thanks guys. Yes, subframe connectors are hanging out on the wishlist.
My Build Thread
post #1093 of 1096 (permalink) Old Dec 5th, 19, 08:09 PM Thread Starter
Matt
Most of the mechanical stuff I have on hand is squared away. So it's the really time consuming and uninteresting task of wiring. Finished the back of the car; made it much more difficult by going with the LED taillights.
ID:	231201   Click image for larger version
ID:	231203   Click image for larger version
really_n0b0dy likes this.
My Build Thread
post #1094 of 1096 (permalink) Old Dec 6th, 19, 08:43 AM
Patrick
It looks like your shop is getting bigger. No more engine and transmission against the wall. The radiator and condenser are no longer in a box.
Now the hard part begins. Where are those little screws that hold the wires in place? Sometimes I look for hours for a little screw or clip.
Looks good!
Patrick
tp_smith is offline
post #1095 of 1096 (permalink) Old Dec 7th, 19, 07:17 PM Thread Starter
Matt
Looks good! [IMG class=inlineimg]/forums/images/Camaros_net_2016/smilies/tango_face_wink.png[/IMG][IMG class=inlineimg]/forums/images/Camaros_net_2016/smilies/tango_face_wink.png[/IMG][IMG class=inlineimg]/forums/images/Camaros_net_2016/smilies/tango_face_smile.png[/IMG]
It's surprising how much bigger the shop feels with everything getting installed into the car. Now it's details..and hours of wiring.
My Build Thread
