69 X11 Engine rebuild & engine compartment resto - Team Camaro Tech
Build Projects follow along start to finish
post #1 of 11 (permalink) Old Dec 23rd, 13, 08:18 AM Thread Starter
Chris
Hatya's Avatar
Well its been about 5 years since I bought this car, and the day I bought it I knew I was going to be redoing the engine compartment. The reason I bought the car was it had a rock solid body with very nice paint, and the interior was in very good shape.
The previous owner had gotten silly and painted everything with a gloss black, it was hideous. And for a lifetime mechanic, there is nothing worse than owning a car yet being embarrassed every time I opened the hood.
After driving the car around for a few years I finally got fed up with the under hood area so much I parked the car and yanked out the 327 planning on performing a light overhaul. But I started to think if I went thru all the work to do a light resto, I wasn't gong to be happy. But as life happens, I knew that I didn't have the time or funds to do a full blown front end resto. So it sat for about a year with no heart, just waiting.
Well here it is about 1 year later, and I finally have the time/motivation/and a few extra buck to get this project started. I just ordered all of the parts to rebuild the 327, actually Im building a separate block to a new 1 pc roller cam 383. And before I set the engine in, I want the front end restored.
So yesterday I finally did the deed, and yanked off the front sheet metal.
My goal is to strip and repaint everything, replace all the brake lines, run new fuel lines and have it back together by spring. Its my 4 time doing this so there should be many surprises. Should be fun times ahead.
Hatya
Daily Driver
327 9.6:1, Performer RPM Heads, 200R4, 3rd Gen P/S Box
Hatya is offline
post #2 of 11 (permalink) Old Dec 23rd, 13, 08:34 AM
Randy
Re: 69 X11 Engine rebuild & engine compartment resto
I bet it is going to look great!
My 69 Camaro build thread:
rsgt is offline
post #3 of 11 (permalink) Old Dec 23rd, 13, 09:51 AM
Kumar
Man if your as picky as I am, that "dominoe effect" will drive you nuts now
"while I've got this off, I might as well do this, and that"....and so on....good luck bud, I've been there, but at least it will look great when your done. Just get most of your parts delivered when your wife is working or away
1969 RS Z28 clone, not the real deal, but meh...i like it
bigarmzz is offline
post #4 of 11 (permalink) Old Dec 23rd, 13, 12:09 PM Thread Starter
Chris
Hatya's Avatar
Lol yup. I'm already thinking just 4 more bolts and the subframe comes out. I'm insisting the car is done by spring so that may curb my aggression a bit. And rule 1 is that it's a driver so that should help me from getting to carried away. We'll see
Hatya
Daily Driver
Hatya is offline
post #5 of 11 (permalink) Old Dec 23rd, 13, 01:03 PM
Yeah, they are kinda like remodeling an old house... you never know where to stop! I'm sure either way you go, Chris, it'll look good when done.
p.s. Nice to see you back!
buenymayor is offline
post #6 of 11 (permalink) Old Dec 23rd, 13, 03:25 PM Thread Starter
Chris
Hatya's Avatar
Well I actually buy and remodel distressed homes for a living, and my boat gets bigger by 2 feet every time I trade it in. I think I am doomed !
Hatya
Daily Driver
Hatya is offline
post #7 of 11 (permalink) Old Dec 23rd, 13, 03:32 PM Thread Starter
Chris
Hatya's Avatar
One of the things that really kept me from starting this project was trying to figure out a way to safely store my fenders in such a space confined garage. I was going to make a couple cheap 2x4 saw horses and then throw covers on the fenders to protect them.
I went up to Lowes to grab a pack of the $6 saw horse brackets and they where out of stock. So i went over to the storage area and found these wall mount hose brackets, I'd swear they where designed specifically to store fenders lol.
Now the fenders are safely mounted on the wall, behind the car, and out of the way. The fenders are also covered, I just took the covers off for the pic.
Hatya
Daily Driver
Hatya is offline
post #8 of 11 (permalink) Old Dec 23rd, 13, 04:17 PM
Grant
You will have to change the body mounts, so surely it would be just as easy to get the sub-frame and control arms sent off for blasting and powder coating at the same time. You would have them back in a week
How does the diff look?
Widseth is offline
post #9 of 11 (permalink) Old Dec 23rd, 13, 04:33 PM
69-Pace's Avatar
Great storage idea. What color is that blue?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #10 of 11 (permalink) Old Dec 23rd, 13, 07:35 PM Thread Starter
Chris
Hatya's Avatar
I changed the subframe bushings right when I got the car
Diff is a 10 bolt posi that needs to be cleaned and painted. The rear and underside may be next winters project.
Hatya
Daily Driver
Hatya is offline
post #11 of 11 (permalink) Old Dec 23rd, 13, 07:38 PM Thread Starter
Chris
Hatya's Avatar
Dusk Blue if I remember correctly. A friend of mine has an original paint color selector from 1969. The paint color on the car matched the chip nearly perfect.
Hatya
Daily Driver
Hatya is offline
